Need Help With Tile. - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 09:22 AM   #1
ECB
Need help with tile.
I am building an outdoor table, and want to tile the countertop of it like these(probably more like the second one:
I will probably use a granite tile, but my question is, what sort of grout should i use, to prevent any cracking, etc? Would it be best to have the smallest grout line possible?(like maybe butt the tiles together)?
Any other tips, or ideas would be appreciated.
ECB is offline   Reply With Quote
Old 03-29-2010, 10:25 AM   #2
Remodeling Contractor
too small grout joints will crack more. make the joint the same size as the thickness of the tiles. Cracking is from the substrate moving and /or improper contact (less than 90%) when adhering the tile Epoxy grout will hold up better but not very user-friendly.
Old 03-29-2010, 04:36 PM   #3
ECB
Thanks.
Should i caulk around the edges of the tile where it meets the wood?(over the grout)
If so what type of caulk would be preferred?
Old 03-29-2010, 07:16 PM   #4
polyurethane or elastomastic caulking for your project. you can get colored caulking to match the grout at a tile store. Caulk along the wood edge and and change in plain. Corners and horizontal to vertical joints
Old 03-29-2010, 07:19 PM   #5
if your doing small like second pic why not use sanded caulk thru out
The older I get the better I was
Old 03-30-2010, 01:06 AM   #6
ECB
Thanks for the reply's.
So would I just use a sanded caulk around the edges? Is there a specific type or will any do?
Old 03-30-2010, 08:02 AM   #7
again buy at a tile store. They will have the color and type you need.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
