Need Help Installing A Wood Transition Onto Concrete! - Flooring - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 11:20 AM   #1
Need help installing a wood transition onto concrete!
Hey everyone. I recently renovated a condo that I own and I installed ceramic tiles in the kitchen, with individual plank laminate flooring everywhere else. The sub floor is all concrete. I'm trying to install some sort of transition between the ceramic tile in the kitchen and the start of the laminate but having issues. In my home, I usually use a piece of oak transition for hardwood, and then I just use finishing nails to nail it into the plywood subfloor under it. I can't do that onto concrete of course, so what do most people do? I've seen transitions where you screw a track into the floor then snap the wood transition into it but I haven't had any luck with those, the piece it snaps into is always too low, and as this was my first flooring project I also didn't plan ahead properly, so it's not an even line between the ceramic tile and the wood floor. The wood is closer to the tile in some places than others, as I guess I was thinking a transition would just go over top of it so it didn't matter about spacing of the gap. Is there any type of adhesive or something I can use instead? Thanks!
oshkosh is offline   Reply With Quote
Old 02-02-2011, 11:37 AM   #2
DIY staff
Rewards Points: 7,174
I've had success with PL2000 (?) look at the label I can't remember the number exactly--put some books or heavy weights on it as it sets.--Mike--
Old 02-02-2011, 12:17 PM   #3
Thanks I'll try that just reading about it online it sounds really good! Sounds like it's PL 200, PL 300, PL 400 etc for various strengths I guess.
Old 02-02-2011, 01:27 PM   #4
Rewards Points: 200
Floor Doc is offline   Reply With Quote
The Following User Says Thank You to Floor Doc For This Useful Post:
oh'mike (02-03-2011)
Installing prefinished wood over concrete Beaver Handyman Flooring 13 01-03-2011 09:24 AM
engineered wood floor on concrete toastie Flooring 0 11-09-2010 01:53 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 05:33 PM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 04:47 PM
