-   -   Need help installing a wood transition onto concrete! (http://www.diychatroom.com/f5/need-help-installing-wood-transition-onto-concrete-94313/)
oshkosh 02-02-2011 11:20 AM
Hey everyone. I recently renovated a condo that I own and I installed ceramic tiles in the kitchen, with individual plank laminate flooring everywhere else. The sub floor is all concrete. I'm trying to install some sort of transition between the ceramic tile in the kitchen and the start of the laminate but having issues. In my home, I usually use a piece of oak transition for hardwood, and then I just use finishing nails to nail it into the plywood subfloor under it. I can't do that onto concrete of course, so what do most people do? I've seen transitions where you screw a track into the floor then snap the wood transition into it but I haven't had any luck with those, the piece it snaps into is always too low, and as this was my first flooring project I also didn't plan ahead properly, so it's not an even line between the ceramic tile and the wood floor. The wood is closer to the tile in some places than others, as I guess I was thinking a transition would just go over top of it so it didn't matter about spacing of the gap. Is there any type of adhesive or something I can use instead? Thanks!
oh'mike 02-02-2011 11:37 AM
I've had success with PL2000 (?) look at the label I can't remember the number exactly--put some books or heavy weights on it as it sets.--Mike--
oshkosh 02-02-2011 12:17 PM
Thanks I'll try that just reading about it online it sounds really good! Sounds like it's PL 200, PL 300, PL 400 etc for various strengths I guess.
Floor Doc 02-02-2011 01:27 PM
400 :thumbsup:
