Old 08-28-2008, 11:01 PM   #1
Need help installing laminate flooring
I am going to try to install new laminate flooring in my kitchen and need help at the door jams. When I'm cutting the piece that fits inside of the jam can I cut it close where it fits fits snug or do I cut the bottom of the jam off and slid the flooring underneath it? I don't won't a ugly space in between the floor and the inside door jam. If I have to cut it what type of saw would I need. Also, I have square type water heater in the kitchen. Will it be alright to have it sitting on top of the flooring or would this prevent the floor from floating and later cause it to buckle? I don't want to put 1/4 round around the water heater because it would look tacky. Any help would be greatly appreciated.
jdubya is offline   Reply With Quote
Old 08-28-2008, 11:27 PM   #2
Whatamess
You want to cut the casing using a jam saw http://www.amazon.com/Bon-Tool-Co-Un...980327&sr=1-10. Your water heater can sit on top of it no problem.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-29-2008, 08:18 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by jdubya View Post
.....When I'm cutting the piece that fits inside of the jam can I cut it close where it fits fits snug or do I cut the bottom of the jam off and slid the flooring underneath it?...
Yes. An easy method to do this is by taking a section of the flooring (cut-off) and then placing it next to the door jamb...flat.
Next, lay a sharp handsaw, or Japanese Flush Cut Saw onto it. Side of blade on the floor piece. Cut slow and straight. The result is a nice clean cut, that yur flooring will snuggly slide into.
I believe that you can find Japanese Flush cut-type saws in the Big Home Improvement Stores.
Examples:
http://www.amazon.com/Shark-Corp-10-.../dp/B0000224U3
- Build Well -
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 08:38 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
