Old 06-12-2009, 01:35 PM   #1
need help with floor
just started a kitchen reno and tore up old ceramic tile floor. the old tile was laid on a deck mud floor containing radient floor heating. the old tiles came up pretty clean but the old thinset was left behind in most of the floor. the area is 17 feet by 25 feet so i would like to keep the old mud floor intact if possible. can a self leveler be poured on the old thinset and mud floor to make it smooth for new tile. and should i paint on a bonding agent before pouring the leveler. thanks for any help.
gerry1 is offline   Reply With Quote
Old 06-12-2009, 06:29 PM   #2
Remodeling Contractor
use the primer that goes with the leveler and pour away. Remember to use foam spacing around the perimeter to allow for expansion.
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 07:23 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Attaching 3/4 Sturdy Floor with PL 400 jamiedolan Flooring 1 09-04-2008 10:15 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 10:53 AM
