Old 10-14-2012, 10:17 AM   #1
Need flooring advice for walk out basement...
I am remodeling my basement that has a wood foundation but cement floor for my house that was built in 1989. I tore out the original carpet which was heavily glued directly to the concrete floor. Now the cement has a layer of ROCK hard yellow mastic (with trowel marks) and the old carpet backing infused into it. Dry scraping it off is futile. I want to install a floating laminate floor or even a vinyl floor like "ALURE". What is my best option to get off the old glue???..Does it ALL have to come off??...Is there a machine I can rent?....thanks for any advice...What is the easy way out, installing new carpet over the old glue????
jtrom is offline   Reply With Quote
Old 10-14-2012, 11:08 AM   #2
Just how dry is this basement?
Old 10-14-2012, 11:38 AM   #3
Basement seems to be very dry..I can see no signs of any water damage at any time. It is built into a hill and no sump pump was ever installed. I have a small dehumidifier that keeps it at 45% humidity with no problem. It is located in Michigan if that makes a difference.
Old 10-14-2012, 11:50 AM   #4
The reason I asked is both laminite and Alour both can have issues with mold forming under them if there's any rising moisture.
Have you concidered engineered flooring instead? Far more stable, it's below grade rated, can be installed as a floating floor, is no harder to install.
Far better looking since the top layer is real wood not plastic.
Old 10-14-2012, 12:00 PM   #5
I have looked at some engineered flooring but the stuff I have looked at seems out of my price range. I guess my question is how much of the old glue do I have to remove to put in any type of flooring???
Old 10-14-2012, 12:21 PM   #6
Just the high places.
With a foam pad with a vaper barrier under the laminite it should work fine.
Only install a brand that says below grade rated.
Others use partical baord as a filler and there going to fail.
Old 10-14-2012, 02:10 PM   #7
What are your thoughts on glue down vinyl tile?...does that need to be grouted?
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Found mold in my basement, need advice... Durt Ferguson General Discussion 3 06-14-2011 07:48 AM
Advice about Waterproofing Basement Walls Firehawk734 Remodeling 2 12-08-2010 04:23 PM
Basement Flooring Question nsanto17 Flooring 9 12-05-2010 06:23 PM
Flooring for basement with water issues Leoskee Flooring 27 08-27-2008 09:49 PM
