Old 10-20-2012, 08:50 PM   #1
Need Flooring advice for a tricky basement situation!
My wife and I just purchased a house and we would like to finish our basement, however we have a slight hitch as the basement is half covered in old tiles that contain ASBESTOS, we would prefer not to have to pay $3500 to have the removed.
The current tiles that are there cover roughly 1/2 the basement to other 1/2 is concrete. What would be the best solution for putting in flooring and covering up the old tiles? I have been told that if we cover them up we should be ok as the ones that remain are intact and not chipping or cracked.
We have considered sealing the old tiles and then putting in a drycore subfloor over the top and proceeding from there however the drycore is very expensive, and we are looking to do this as cheaply as possible. The other idea we had was to use self leveling concrete to build up the 1/16 of an inch or so around the transition area and spread that out over 2 feet or so to build the area up to that height.
Any ideas or advice on how to do this?
xXXNotMVAMXXx is offline   Reply With Quote
Old 10-20-2012, 11:35 PM   #2
Pro Flooring Installer
rusty baker's Avatar
You can put carpet, laminate or engineered right over tiles with no problem.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following User Says Thank You to rusty baker For This Useful Post:
ToolSeeker (10-21-2012)
Old 10-21-2012, 07:55 AM   #3
Any issues with the floor not being level, or where the transition is?
Old 10-21-2012, 08:34 AM   #4
Super Moderator
Use 'Feather Finish' by Ardex to feather in the height differance----Self leveling compound can be used to fill low spots.
oh'mike is online now   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Advice on priority of repairs: gutters and basement nshroyer Building & Construction 10 07-06-2011 09:40 PM
Advice about Waterproofing Basement Walls Firehawk734 Remodeling 2 12-08-2010 04:23 PM
Advice for a novice: Mold and water damage in basement xoxJanette General Discussion 1 12-29-2009 07:54 AM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 10:08 AM
