Old 01-29-2013, 04:59 PM   #1
Need to cut old wood flooring installed under a wall
I'm in the middle of replacing carpet and old parquet flooring with new wood laminate. The project was going well until I ran into a spot in the room where sliding doors and a wall had been installed between two areas of the room.
The walls were built directly on the parquet floor and are nailed into the tiles. The wall is about 9" wide and has two sets of parquet tiles running the length of it. I tried to remove the parquet by hammering it out from the side and pulling it out with a pry bar, hammer, etc.
My next idea was to cut around the wall.
Does anyone have advice on how I could cut the tiles around the wall base to leave them in place and then butt the new laminate floor against it? The tiles are on a concrete subfloor.
JohnfromTexas is offline   Reply With Quote
Old 01-29-2013, 05:18 PM   #2
Toe Kick saw or Ossilating saw.
Why remove it and not just go over it?
Old 01-31-2013, 04:06 AM   #3
Joe, If the parquet were not removed, that section of the floor would be 1/2" higher than the rest of the concrete floor. How are you going to install lam at differing heights? Or are you suggesting the OP bring the rest of the floor up to the height of the parquet?
To the OP, like Joe said, Oscillating saw or toe-kick saw. I'd go with the toe-kick. should be quicker. you can usually rent either one. You certainly don't want to try removing it from under the wall (bottom plate).
Seattle2k is offline   Reply With Quote
Old 01-31-2013, 05:47 AM   #4
Super Moderator
I've had good success with a SawsAll----long blade, mounted upside down----press the blade against the wall--make a shallow skim cut---
Tags
flooring advice, tools
Framing a wood studded wall against a concrete block wall miamicuse Remodeling 7 04-25-2012 09:23 AM
Wood basement wall below grade - what to do? Jer739 Building & Construction 1 10-04-2011 11:03 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 07:21 AM
