Need Advice For Tile Hearth Pad - Flooring - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 02:54 PM   #1
Need advice for tile hearth pad
Hi,
I plan to build a hearth pad for a wood stove and need advice. What I plan is a 5' wide x 4" deep hearth pad in a location which now has wall - to - wall carpet. I want to cut the carpet out and place 1/4" Hardie Backer, and tile with 12" porcelain tile. I'm trying to get the pad as flush with the carpet as possible because it will be in an area with some foot traffic. It will be against a wall. The stove only requires ember protection, no R value.
I have several questions:
1. Is this a good plan at all or would you advise a different approach?
2. How can I keep the carpet from pulling back assuming it's stretched?
3. Best way to trim around the pad?
4. How to attach the backer board to the floor?
5. What kind of thinset to use?
I can usually get stuff done once I know how to start, but I know nothing about flooring.
sprinter is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
River Rock Hearth for Wood Stove Borges Remodeling 9 11-02-2008 01:39 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
