Need 2 Inch Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-15-2008, 04:07 PM   #1
Need 2 inch floor
My toilet flange is 2 inches above the floor joist. So I need to build a floor that is close to 2 inches. Here was my plan
3/4 ply
1/2 backer board
3/8 marble tiles
So Approximately this gives me 1 and 3/4 inches of floor leaving me with 1/4 to make up. I do not want to use a motar bed cos I have had bad experience with that. Can anyone suggest a way to get to 2 inches using a combination of plywood and backerboard?
Any suggestion will be appreciated
padola07 is offline   Reply With Quote
Old 08-15-2008, 05:00 PM   #2
Custom Cabinet Maker
double 3/4 plus 1/2" durock. If ya need tile space then double 5/8.
skymaster is offline   Reply With Quote
Old 08-15-2008, 05:54 PM   #3
ccarlisle's Avatar
Two 3/4"s, thinset, DITRA, thinset, tiles.
Don't pee on the tiles, or you'll see it.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Tile on concrete floor....with 1/8th inch cracks.. tigerbalm2424 Flooring 23 06-21-2008 09:01 PM
is 0.25 Inch tile thick enough to go on the floor ? amakarevic Flooring 3 05-04-2008 11:22 PM
