Old 07-03-2009, 12:30 AM   #31
Tileguy
What about an acid etch after the stripper? I know not as effective as a grinder but in principal would it not be roughly the same thing? The stripper removes the paint and the acid etch cleans and scuffs the surface. Could this save her from all the mess and dust?
Just for the the record........
Paints and sealers are known industry-wide to be bond breakers when it comes to tile. It IS NOT RECOMMENDED that tile be installed over any painted or sealed concrete surface.
To remove paint or sealers from concrete surfaces chemicals should not be used, chemical strippers are also known bond breakers. The only industry-acceptable method of removal is through mechanical abrasion. Sandblasting, shot blasting, scarifying, grinding.
The product that I used is water soluble and I of course washed it with a mild soap and rinsed 3 times. I really do think that there is no stripper residue there.
Old 07-03-2009, 01:03 AM   #32
toolbelt Tina's Avatar
Default ok then...
Bud so what you are saying is....
I hope the grinder does not create the amount of dust like a concrete saw.
I'm sure she'll tackle the challenge well. Perhaps even start a blog
toolbelt Tina is offline   Reply With Quote
Old 07-03-2009, 01:19 AM   #33
Tileguy
Well of course it does!
Old 07-03-2009, 06:31 AM   #34
never use soap,,, we use dawn ' when necessary,,, i have no financial interest in recommending that product &, if sent $$$, will donate to this thread
yesitsconcrete is offline   Reply With Quote
Old 07-03-2009, 11:33 AM   #35
yummy mummy's Avatar
Yes, I do get you Bud about the paint removers......
I will just pray that they don't move.......and my clients don't care.......
If I was doing this as a profession and for paying clients......I would definitely hire someone and have it removed mechanically.
yummy mummy is offline   Reply With Quote
Old 07-03-2009, 11:35 AM   #36
I have already starting laying the tiles........and looking for movement and cracking.........lol
I am hoping that they won't all crack. If a few crack, I love rugs......
More On This Topic
You love your kitchen floor because of the real tiles laid on it. You like the color, but you like the color even better when the tiles are wet, and they look more vibrant. But read below for some other ways to add some shine to your ceramic or slate... Read More »
When it comes to sealing tile, it's almost always a good idea to seal the grout. However, you should decide on a tile sealer on a case-by-case basis. Sealing certain types of tile may cause the tile to become darker. You should always follow all... Read More »
Stripping old paint is often the first step in a redecorating project, whether it's a piece of furniture or a window frame. Chemical paint strippers are effective tools for any do-it-yourself enthusiast, and even a beginner can quickly learn how to strip... Read More »
How to Seal Tile
How to Seal Tile by eHow.com
Most tiles used in homes are glazed, and the glazing process creates a seal. But if you use porous materials, such as terra cotta, marble or slate, you will need to seal the tile to keep the surface looking good and to prevent stains on that surface you... Read More »
Concrete floors are long lasting, well supported and fairly simple to maintain. With stamps, patterns, stains and polishes, they are popping up in places beyond the garage and basement. Cleaning your concrete floors should be part of a regular home... Read More »
Laying dura ceramic tiles on concrete monte Flooring 24 04-29-2009 08:53 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 06:57 AM
Flashing NoExperience Painting 13 09-04-2008 07:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 09:18 PM
Flat over Semi-Gloss dankreboot Painting 10 07-06-2008 12:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
