12-11-2008, 12:11 PM
#16
There is a saying. If the paint won't stick then anything you put over the paint won't stick.
I never trust paint (just like I never trust wallpaper). I have seen to many times when it was put on dry (not enough moisture to allow it to stick to the surface) and it peals in just about any situation. They put it on dry thinking that it keeps from dripping and they are too lazy to want to do any cleanup or put down drop clothes. Many times people don't use the right paint for the right situation.
For this reason I am a big fan of removing paint and wall paper if needed.
My idea of a perfect day: No where to go and all day to get there.
12-11-2008, 12:21 PM
#17
K&B Remodeler/Tile Guy
Originally Posted by yesitsconcrete
angus, is that the bosch 4" conc planer ? ? ? we use std 7"/9" 15a grinders,,, MUCH faster & MUCH less expensive ! ! ! beaneedoo works but it leaves its own stains/mess.
It's the Bosch 5" concrete grinder.
http://www.amazon.com/Bosch-1773AK-C.../dp/B0000719W8
I have to remove thinset from concrete in small bathrooms (powder rooms) at times and this works perfect. If I have a need for anything larger, my neighbor is an excavator and will let me borrow whatever scarifier I need!
12-11-2008, 12:55 PM
#18
thought it was,,, see 'em on ebay but grinders're so much faster, easier, & cheaper or it is w/our method.
we also have scarifiers ( 5 & 11hp ) but they're for pools & other ext work.
12-11-2008, 01:23 PM
#19
Angus:
The pic makes it look easy......
I just don't want paint particles and concrete particles all over the air.
But since there is an vac attachment then this does seem like a possibility.
What is that thing called? Do they rent it out at the big box stores?
And the vaccuum, does that come with the grinder.
Do I have to get right to the bare concrete?
I think underneath there is another coat of paint which probably is the original one from 70 years ago.  and that probably has really bad stuff in it. When I start to grind it, won't it be harmful to breath in?
OK, I'm repeating, yes I can, yes I can,..........no I can't
12-11-2008, 10:01 PM
#20
Tileguy
Yummy,
Isn't this the same thread you have running over at The Floor Pro where earnest experienced people have been trying to convince you of the same information you are getting here?
I can't tell you how used it makes me feel when you people do this crap. I thought I was being helpful but it seems this is just a game to you.
What's the matter with you?
12-12-2008, 01:27 AM
#21
Bud
Don't get bent out of shape, sweety.
I did not realize that there was a problem in posting on another forum with the same question to see what the pros there think.
Drop the attitude Bud......
......and if you want to express your displeasure, there are many ways of doing that.
12-12-2008, 01:41 AM
#22
Originally Posted by yummy mummy
Angus:
It's a concrete grinder. Not sure if big box stores rent it. When I need a tool, I unfortunately have to just buy it  .
I can't imagine it would be hard to find though. It's the perfect tool combo for your situation. SOMEONE has to rent it. Try just a regular ole rental store. There's actually one right across the street from my local home deplore. Has a lot more to offer than the apron place.
...and yes, you have to go to bare concrete.
and yes, you CAN do it.
12-12-2008, 10:18 AM
#23
Thanks Angus. I'm pretty certain I can find one in my area.
We have many rental places.
................and you know what, YES, I can do it.........and I am going to do it.
Hopefully after the holidays.
12-12-2008, 10:49 AM
#24
be surprised if the avg rental place has angus' bosch OR a dust-shroud fitt'd grinder,,, then again, most use grinders,,, our orange apron rental dept's got 1 even tho most dit-ers/h-o's don't know what it is,,, if you can't hook this up to a wet/dry vac, you'll never lay the floor.
07-01-2009, 09:20 AM
#25
I have a similar situation where the basement has been painted with Primer and Behr Flooring Paint. The paint has been on for for about 8 years and has not peeled.
I was at a Tile store yesterday and the person said that I can put concrete directly on the painted basement wall and it would be fine? Is there some special type of cement that will support this?
Also, how about paint remover? Can I use this to remove the paint before laying out the tile?
Thanks for your help!!!
07-01-2009, 05:56 PM
#26
To remove the paint from the floor, I used an enviro friendly product as I did not want the toxic smell. The product that I used is called Safe strip.
I found it to be great. I don't know how much area you need to do, but it is a lot of work.
Good luck
07-01-2009, 06:06 PM
#27
Tileguy
Just for the the record........
Paints and sealers are known industry-wide to be bond breakers when it comes to tile. It IS NOT RECOMMENDED that tile be installed over any painted or sealed concrete surface.
To remove paint or sealers from concrete surfaces chemicals should not be used, chemical strippers are also known bond breakers. The only industry-acceptable method of removal is through mechanical abrasion. Sandblasting, shot blasting, scarifying, grinding.
Carry on.
07-02-2009, 07:19 AM
#28
i don't know of any pro who'd use less than mechanical means to prep a floor,,, yes, there are solutions/solvents/poultices/potions which'll soften paint/cutback/emulsion/mastic & can do so while being environmentally safe, planet-friendly, go suck an egg
the main drawback to the aforementioned wish list is getting the NEW grout/thinset to ADHERE to the greasy surfaces left behind by tree-hugging-stuff-in-a-can,,, i can't believe ANYONE'd be stupid enough to say that ANYONE ( bud & me includ'd ) can put concrete directly on the painted basement wall and it would be fine,,, that's just idiotic & should insult anyone's intelligence
now having had my daily small rant, ignorance is another issue &, thankfully, there's a cure for that - EDUCATION ! ! ! HIE THYSELF TO ANOTHER STORE toot sweet ! ! !
07-02-2009, 11:14 PM
#29
what about an ...
what about an acid etch after the stripper?
I know not as effective as a grinder but in principal would it not be roughly the same thing?
The stripper removes the paint and the acid etch cleans and scuffs the surface.
Could this save her from all the mess and dust?
07-03-2009, 12:23 AM
#30
The product that I used is water soluble and I of course washed it with a mild soap and rinsed 3 times.
I really do think that there is no stripper residue there.
At least, I am hoping there isn't.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
