Old 12-10-2008, 10:22 AM   #1
yummy mummy's Avatar
Default Is it necessary to get rid of paint on concrete before laying ceramic tiles?
My basement concrete floor is painted with what I assume is some type of concrete paint. It is shiney at parts, and some parts have worn out.
I eventually want to lay ceramic tiles and I don't want to use ditra, I simply want to lay them over the concrete. (The concrete has no cracks, no chance of moving as it is 70 years old.)
Do I really need to remove the paint in order for the adhesive to stick?
Thanks very much for any help.
Also, there is a certain part that I will have to use some type of self levelling compound. Would the compound work with the paint being there?
yummy mummy is offline   Reply With Quote
Old 12-10-2008, 10:40 AM   #2
Default Yummy,I think sanding will do
Try a spot with the glue/mastic your going to use to set the tile .See if it eats the paint.If not get a 4" belt sander with 60 or down to 30 grit sanding belt.Rough it up and you should be good to go.
As for leveling I don't know a thing about that.
BBGun Bob
SE Mich.
bbgunbob is offline   Reply With Quote
Old 12-10-2008, 01:45 PM   #3
Can I sand and rough it up by hand? Would that work?
I just want to make certain that the adhesive will stick to it.
So that the tiles will not end up moving and cracking.
Old 12-10-2008, 01:52 PM   #4
Yep you can that way a machine just saves time and labor.
Bob
Old 12-10-2008, 06:37 PM   #5
Tileguy
NONSENSE!!!
You don't use mastic with floor tile.
Thinset wont eat anything but your hands.
Where on earth is this notion coming from?
The Tile Council of North America publishes a "Handbook for Ceramic Tile Installation"
YOU can order one here: http://www/tileusa.com
Old 12-10-2008, 06:39 PM   #6
Tileguy
Yummy,
Painted concrete surfaces are a well known bondbreaker for all tile thinsets and self levelling compounds and must be removed prior to installing tile.
Old 12-10-2008, 09:18 PM   #7
Try a floor machine from a local rental place. You will want a very aggressive pad to remove paint. They are powerful and easy to operate once you get the hang of using one they work really well.
Jamie
jamiedolan is offline   Reply With Quote
Old 12-10-2008, 11:26 PM   #8
Originally Posted by Bud Cline View Post
Yummy,
Hi Bud
Would sanding it to the point where I remove all the shine be enough?
Or, (please don't say it,,,,,,,,,) have to remove it completely to the bare cement? Oh no.........................
Old 12-11-2008, 12:59 AM   #9
Tileman-Manufacturers rep
Hi Bob, neighbor. Welcome to this forum, BUT that is what happens when you make recommendations that do not pass the "do-it-right" test.
Only hacks use mastic on floors. You could use it on back splashes in dry areas and that's about it. We do not recommend tiling over painted floors, it'll come loose one day.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 12-11-2008, 01:59 AM   #10
K&B Remodeler/Tile Guy
angus242's Avatar
Paint's gotta go but Bud and Jaz have already confirmed that.
Note, before you use an SLC, you will most likely need to remove the paint AND use a special primer. I have only used Mapei Novoplan 2 and you have to use the primer over a properly prepared cement surface.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 12-11-2008, 02:35 AM   #11
Jamie
I have also used a floor machice with a pad to remove paint from concrete and it works well. One time however I tried it on a concrete patio and was unsuccessful. I then used a pressure washer - it removed the stuborn paint super easy. Not knowing if your basement will allow for this - has a drain, etc. - but may be a consideration.
Vince
vsheetz is online now   Reply With Quote
Old 12-11-2008, 10:23 AM   #12
Ok, I get it..........I have to remove the paint.
I don't want to do it with a machine because it will probably send me flying into the air.......
What can I use to remove it, by hand. I don't want to use any chemical products.
I think the paint is oil based. How would I know?
Old 12-11-2008, 10:39 AM   #13
it doesn't take long to learn the scarifier OR a conc grinder's technique.
we typically use hand grinders fitted w/dust shrouds hook'd up to wet/dry vacs running turbo-style diamond cup wheels either 12 or 24 segs,,, your apron store might rent these,,, usually any paint hasn't penetrated that far into the conc to interfere w/a new surface however occasionally you may need to install a polymer-modified overlay if nec.
yesitsconcrete is offline   Reply With Quote
Old 12-11-2008, 11:20 AM   #14
angus242's Avatar
Oh you are a glutton for punishment....by hand? That's too much work.
If you could rent a setup like this, it would be very manageable:
I own this combo and it will beat the heck out of doing it by hand (and no, that's not me in the pic). Notice the vacuum? It automatically turns on when the grinder is switched on. Catches about 90-95% of any dust that it created by the grinding.
Finding something like this will save you hours over doing it by hand.
Say it with me...."I can do this. I can do this...."
As for the paint, maybe someone can verify this but rumor has it, rubbing alcohol will remove latex paint but not oil.
Angus
My Albums
Old 12-11-2008, 12:00 PM   #15
angus, is that the bosch 4" conc planer ? ? ? we use std 7"/9" 15a grinders,,, MUCH faster & MUCH less expensive ! ! ! beaneedoo works but it leaves its own stains/mess.
More On This Topic
Hand painted decorative tiles add a special touch to many homes today. In a generation where home owners look for those little things that make their homes stand out from the rest, decorative tiles are a great way to accomplish that goal. Keep reading to... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
You love your kitchen floor because of the real tiles laid on it. You like the color, but you like the color even better when the tiles are wet, and they look more vibrant. But read below for some other ways to add some shine to your ceramic or slate... Read More »
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
Hi my name is Jeremiah Johnson; I’m the owner and operator of S&J Cleanaway. I’ll be demonstrating how to remove adhesives from a floor, this can also double for non-stick pads inside of a shower or bathtub or just anything that would... Read More »
Laying dura ceramic tiles on concrete monte Flooring 24 04-29-2009 08:53 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 06:57 AM
Flashing NoExperience Painting 13 09-04-2008 07:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 09:18 PM
Flat over Semi-Gloss dankreboot Painting 10 07-06-2008 12:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
