You won't float the grout over the full surface, rather you need to use a grout bag--it looks like a big cake decorating bag. It's also handy to have a little trowel flout (the kind that are about 1.5"x4" or so), you can use that to help pack the grout into the joints if needed. You'll still get some "mess" on the edges of the slate, but it's much easier to clean up than the whole tile.
Good Luck.
The color is up to you, maybe a dark gray or charcoal color.
As for grouting, what was said above would help, but I think those grout bags for grouting are a waste of time, first thing is to give that stone at least 2 coats of a good sealer, then grout with a normal float and use the short edge if you like to pack it in without going over the whole tile if possible, with slate, do a small section at a time and get right on it and clean it, then continue, don't let it get ahead of yourself.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
