Nails Are Cracking My Quarter Round Trim - Flooring - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 12:01 PM   #1
Rewards Points: 41
Nails are cracking my quarter round trim
Novice here... Nails are cracking my quarter round trim. The quarter round appears to be made out of some sort of plastic instead of wood. Should I just use liquid nails to attach to wood trim?
Or are my nails to big?
Thanks for any and all help!
dbower is offline   Reply With Quote
Old 01-21-2012, 12:03 PM   #2
Civil Engineer
Rewards Points: 4,854
You can predrill the holes for the nails, use a drill equal to the diameter of the nail shank.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
dbower (01-21-2012)
Old 01-21-2012, 12:07 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
And it sounds like your nails are too big. I have installed many, many feet of that plastic crap and never cracked any.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
BigJim (01-21-2012), dbower (01-21-2012)
Old 01-21-2012, 01:55 PM   #4
Rewards Points: 41
Thanks for the info all!
Rusty, are you installing the trim without pre-drilling? Would like to avoid, if possible.
Old 01-21-2012, 02:30 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 412
The nails are too big, what are you using? Moldings will also crack if you fasten too close to an end.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
dbower (01-21-2012)
Old 01-21-2012, 02:34 PM   #6
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
It's amazing what clipping the tips or blunting the tips of the nails will do to stop splitting wood, but I don't know about the plastic stuff
('cause I'm a carpenter so all I know about is wood).
titanoman is offline   Reply With Quote
The Following 2 Users Say Thank You to titanoman For This Useful Post:
dbower (01-21-2012), del schisler (01-23-2012)
Old 01-21-2012, 02:44 PM   #7
Rewards Points: 146
I never pre-drill. Dulling the ends as suggested can help, too.
The Following User Says Thank You to rusty baker For This Useful Post:
dbower (01-21-2012)
Old 01-21-2012, 02:53 PM   #8
Rewards Points: 41
What size nails to you recommend?
Thanks for the responses!!
Old 01-21-2012, 02:55 PM   #9
Disabled wood vet
titanoman's Avatar
Like a 4d x 1-1/2.
Old 01-21-2012, 03:21 PM   #10
firehawkmph's Avatar
Rewards Points: 1,902
18 gauge brad nailer.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-21-2012, 03:31 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 412
Thanks Mike. But if the DIY'er had a compressor and finishing nailer, we wouldn't be having this thread to answer. You're right of course, nails are no way to install moldings.
Jaz
Old 01-21-2012, 03:37 PM   #12
Disabled wood vet
titanoman's Avatar
Mike Hawkins
I doubt they have a compressor or the wood wouldn't be splitting.
Old 01-21-2012, 06:26 PM   #13
I will rent a compressor and a nail gun which i think will take care of the problem.
florida56 is offline   Reply With Quote
Old 01-22-2012, 02:51 PM   #14
Most people know somebody with a brad tacker. I bought a porter cable that was a factory reconditioned for $35. Cheap enough to add to your toolbox even if you are just a homeowner. Plus they're fun to use.
Mike Hawkins
Old 01-23-2012, 04:05 AM   #15
Jaz
What is the best way to install trim? I have an older home (1899) and the quarter round trim needs replacing in some areas. The current trim is nailed but after I pull it, what do you recommend?
Sartrean is offline   Reply With Quote
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 09:20 AM
Baseboard or Quarter Round for Laminate Floor sweaty General DIY Discussions 10 08-03-2011 04:15 PM
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 09:00 AM
Type of nails for exterior trim bluefitness Building & Construction 2 12-07-2008 08:01 PM
