Nailing Luan - Flooring - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 02:12 PM   #1
Rewards Points: 40
Nailing Luan
Been a few years (15-20?) since I put down Luan and I swear it was nailed every 6 inches back then and now I read every 4 inches according to the manufacturers site. Is this really necessary?
Second question is regarding fastener length. I already have a 5 pound box of the proper ring shanked nails but they are too long and will go all the way through. Is that a big no no??
This is going over a good solid 3/4 plywood sub-floor over an insulated crawlspace and being prepped for new vinyl sheet flooring. Using 5mm 4x 8 sheets from here http://www.taracapacific.com/products.html#nogo
Thanks!!
Whiskerfish is offline   Reply With Quote
Old 02-29-2012, 02:19 PM   #2
you should not use Luan it has voids in it.
Hardway is offline   Reply With Quote
Old 02-29-2012, 02:36 PM   #3
Rewards Points: 40
Maybe I am calling it by the wrong name. The manufacturer calls it Tri-Ply Underlayment. Guaranteed not to have voids.
Old 02-29-2012, 02:42 PM   #4
you were calling it the wrong name. someone else will be along. but that is the correct nailing patter.
Old 02-29-2012, 02:48 PM   #5
4" on the field and 2" on the edge
yes
http://www.halexcorp.com/halex_underlayment_3.shtml
Old 02-29-2012, 03:57 PM   #6
Rewards Points: 14,306
I never use nails any more. They can rust and cause staining. Takes to long to have to go back and fill all the nail holes and hammer marks with leveling compound and nail all those nails.
Use a narrow crown pneumatic staple gun with 1" staples.
Set in touch and go I can attach a whole sheet in about 1. min. The holes are so small you do not have to go back and fill them in. You still will have to fill in the seams with leveler.
Old 02-29-2012, 07:48 PM   #7
Rewards Points: 40
Thank you Gentlemen!
Unfortunately this will be done in several steps (over several weeks) so renting a stapler is not an option nor is buying one just for this job. So I will be doing a lot of nailing
Is there a recommendation for a premixed leveler??
Old 02-29-2012, 07:51 PM   #8
good luck
Old 02-29-2012, 07:57 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 422
Yes, leave it on the store shelve to collect dust.
Jaz
Old 02-29-2012, 08:55 PM   #10
Rewards Points: 528
Jaz
framer52 is offline   Reply With Quote
Old 03-01-2012, 06:13 PM   #11
Rewards Points: 40
Jaz
I appreciate the response but that does not help me a lot. Are you saying not to use a premix or not to use a leveler or what? This is a 300 square foot room and putting a nail every 4 inches I am sure there are likely to be some dings in the floor that will need addressed.
Any recommendations on a specific product would be appreciated.
Old 03-01-2012, 06:43 PM   #12
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Buy a cementious based filler. A powder, not a premix.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 03-02-2012, 07:09 AM   #13
Rewards Points: 40
Got it .
Thank you very much
How To Remove Luan djmdoitmyself Flooring 5 03-13-2016 09:18 AM
Nailing Rigid Foam Boards to Plywood Buscador Roofing/Siding 5 02-05-2012 06:22 PM
Luan plywood staples under tile? former33t Flooring 3 10-15-2009 01:34 PM
Ripping up luan flooring Mike2181 Flooring 5 10-04-2009 12:08 PM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 02:46 PM
