Nailing Bamboo Over Parquet Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 04:15 PM   #1
Nailing bamboo over parquet flooring
I jus bought solid bamboo flooring and I want to nail it over the existing parquet. My parquet is in good shape, no pieces coming up but I'm worried if I nail to it, it will listen up or even over time whatever glue is under it will deteriorate. If I get a long enough nail that goes through the parquet and into the ply would that cut it?
Any thoughts on this would be appreciated. Thanks.
luther is offline   Reply With Quote
Old 11-04-2011, 04:23 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Any flooring is only as good as what is under it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-04-2011, 05:02 PM   #3
Fair enough, but is parquet flooring good enough to be under it is my question. The floor is solid so the plywood below the parquet is good.
Old 11-04-2011, 05:38 PM   #4
DIY staff
Rewards Points: 7,174
It could be done--but it's a chancy install----If the parquet is old enough to need replacing--the glue holding it down is probably old and brittle---driving flooring spikes into that on an angle might be all it takes to knock some loose.
If you are willing it risk failure in order to save the time involved in removing the old parquet--It's your house .---Mike---
Old 11-04-2011, 05:50 PM   #5
I picked a spot where I'm going to pull the parquet up anyway to install tile to do some testing. I drove a framing nail into it and it didn't split or come loose. I managed to get a chunk free in a corner after pulling the trim off. I didn't realize it's only 1/4" thick. If I use a 2 1/2" nail Ive got a good hold into the floor. Over time though things might get noisy as the parquet glue deteriorates.
Really, I don't mind pulling up the parquet, but I need to have the hight in order to match the kitchen and bathroom tiles so what I'm trying to avoid is buying a bunch of plywood and installing it first.
Old 11-04-2011, 06:42 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Isn't the parquet oak? Might be a challenge using a pin that long.
My Bamboo Flooring Experience schraggyj Flooring 3 08-21-2011 06:24 PM
bamboo flooring sueriles Flooring 9 07-11-2011 06:55 AM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 10:11 AM
a few questions about bamboo flooring installation bostonmike Flooring 2 01-19-2008 09:06 PM
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 03:36 PM
