Nailer Too Strong? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-08-2014, 04:01 PM   #1
Rewards Points: 150
Nailer too strong?
Hey guys!
I am about 100sf into a 900sf project. I am experiencing tongue splitting on about 1/3 of all the nails I put in this stuff. I have read contradicting views of what should be done here...some say to oil the nails, some say invest in a lighter duty nailer and nail, some say it will be fine the way it is. I have added duct tape to the base plate to get the cleat backed up a bit, but it still lands out of the pocket (and splits tongue). I can't add anymore tape because the nailer barley catches the edge of the plank as it is now. I can get the boards to meet up ok if I scrape out the broken bits. This is not an emergency by any means, the floor looks great so far, I'm just worried about cracking and creaks in the future.
Details:
1/2" sandalwood/pressed Mazama/BuildDirect 5" wide
Subfloor is 3/4" OSB very low moisture
Harbor Freight pneumatic nailer w/ 2" L shaped cleats
I am in NC. It will be very humid this summer.
I believe I have followed all of the manufacturers instructions.
http://www.builddirect.com/Hardwood-..._10090528.aspx
Thanks again. This site is great!
joemontana16 is offline   Reply With Quote
Old 05-08-2014, 05:21 PM   #2
Rewards Points: 344
You need a smaller nailer with a base set for 1/2". Your big one will just continue to blow out the tongues....and think about staples instead of the L shaped. Ron
ront02769 is offline   Reply With Quote
Old 05-08-2014, 06:35 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
I'm using the same HF nailer with cleats but on 5/8" solid Bamboo....I've had a couple of tongue's split.
But for any thinner wood....yea....staples...
Old 05-08-2014, 08:37 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
I agree that cleats for 1/2" wood is way too thick a gage. The instructions mention 15 gage nails or staples.
Also, industry standards say that any wood 5" and wider should also be glued in addition to fastening. No mention of that in the Maxama installation sheet though. Are you installing over felt paper?
Jaz
Old 05-08-2014, 08:44 PM   #5
Rob
Robpo's Avatar
Rewards Points: 826
I would try angling the nails more and standing on both sides and nailing between your feet
Robpo is offline   Reply With Quote
Old 05-08-2014, 08:46 PM   #6
JOATMON
ddawg16's Avatar
Originally Posted by Robpo View Post
I would try angling the nails more.
Well....if he is using the same HF floor nailer I am....kind of hard to do....angle is fixed.
Old 05-08-2014, 08:47 PM   #7
JOATMON
ddawg16's Avatar
Jaz
Jaz....how would one glue is using felt?
I'm close to doing my stair treads with the bamboo....I used felt for the floor but I was NOT going to use felt on the stairs...lots of glue and nail in a couple of key places.
Old 05-08-2014, 09:08 PM   #8
Rewards Points: 150
I am installing over felt #30 for a little more cushion. I have read that the humid summers and dry winters in NC will crack most flooring if glued and nailed. There is so much conflicting info on the internet!!
I have added some height to the bottom plate and things are going better, although I might go check out a different nailer tomorrow. Can you guys recommend a smaller gauge gun that would be good for 1/2" planks?
Aren't 15 gauge nails the same as cleats?
Old 05-08-2014, 10:08 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 340
You wouldn't of course. One reason I bought 4" instead of wider planks. Even my 4" suggested the option of also gluing. Of course if you go with wide and want/need to also glue, you can use a liquid applied membrane/glue.
You don't want or need tarpaper on the steps.
I would have used 15lb, Does Maxama say 30lb? More cushion? You don't want cushion in hard floor coverings. You need to monitor the humidity levels all the time.
Tell me about it........ Don't believe what you see/read on the internet, except. What the manufacturer say, and what we say here!
I've only used 2" cleats on 3/4" hardwood. Cleats come in various gages, 16 & 18 seem to be common. The instructions say 15 gage, so..............Many installers like staples better.
Can we see a couple of pics of how the cleat hits the tongue?
Jaz
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 07:58 AM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 01:16 PM
Which cordless nailer should I buy? Mike2181 Tools 8 09-23-2009 01:04 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 03:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
