Nailed OSB Subfloor - Should I Screw It As Well? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 10:21 PM   #1
Rewards Points: 169
Nailed OSB Subfloor - Should I screw it as well?
I just nailed a subfloor using OSB. Should I go over it again with screws? I did not glue it.
RCGA is offline   Reply With Quote
Old 03-12-2013, 10:31 PM   #2
Rewards Points: 12,808
Big mistake already, constution adheive would have added 25% more strength.
Is it at least T X G subflooring?
What kind of nails did you use.
Old 03-13-2013, 06:36 AM   #3
Rewards Points: 169
It is an older (~35 years) home, so it had a plank sub floor, then we put the OSB over that
Old 03-13-2013, 10:42 AM   #4
Rewards Points: 169
Oh and it is t&g. I'm thinking about just screwing over the high traffic areas. The rooms itself isn't that big, it's under 150sqft
Old 03-13-2013, 10:48 AM   #5
Then no glue is fine.
Those old boards should have had screws added before the osb.
The OSB needs to be nailed or screwed every 4" on the edges and 6 to 8" in the field not just in the traffic areas. If not it's going to flex and squeck.
Old 03-13-2013, 10:52 AM   #6
Rewards Points: 169
Old boards were nailed. Is that going to be a issue in the future? Under the floor is an undeveloped basement. Maybe I could do something from below?
Old 03-13-2013, 11:06 AM   #7
There's nothing worthwhile you can do from below for now.
No screws in the old floor may cause squecks.
Old 03-13-2013, 02:28 PM   #8
Rewards Points: 150
Joe means squeaks.
Do you have squeaks now - is that a problem?
zakany is offline   Reply With Quote
Old 03-13-2013, 04:19 PM   #9
Rewards Points: 169
Originally Posted by zakany View Post
Joe means squeaks.
Nope, no squeaks - but I just bought the house.
Old 03-13-2013, 06:50 PM   #10
Rewards Points: 744
Did you at least use ring-shank nails?
Seattle2k is offline   Reply With Quote
is ground screw on light switch necessary SS396 Electrical 17 01-12-2013 04:48 PM
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 09:30 AM
Nail Shear Strength Test ddawg16 Building & Construction 32 08-24-2012 10:17 PM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Breakers that could take 2 wires under one screw latinomusician Electrical 25 06-24-2010 07:19 AM
