Nail Or Staple Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 11:23 AM   #1
Newly Retired
tuchodi's Avatar
Nail or Staple Hardwood
I am going to install about 1200 sq ft of 3/4" oak pre-finished hardwood. Which do you prefer 2" nails or 2" staples. I will be using a Bosch air floor nailer.
tuchodi is offline   Reply With Quote
Old 10-17-2010, 12:14 PM   #2
jlhaslip's Avatar
Rewards Points: 2,884
nails, because they are more readily available where I live.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-26-2010, 10:25 AM   #3
Newly Retired
tuchodi's Avatar
I can buy either so that has no bearing on the end result. Just need to get opinions on what people have used and if one is better than the other both for ease of use and does one hold better than the other.
Old 10-26-2010, 01:00 PM   #4
jlhaslip's Avatar
I'd still use the nails/cleats for solid wood. Staples are good for engineered floors since they are easier on the tongues.
Old 10-26-2010, 11:37 PM   #5
Nails/cleats work just as well as staples , If you are putting an extremely hard exotic down , Then cleats penetrate better with less splitting , tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
Old 10-27-2010, 09:28 AM   #6
Newly Retired
tuchodi's Avatar
Thanks I will most likely use cleat/nails then
What staple gun or nail gun for subfloor justdon Flooring 4 03-31-2011 03:16 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
regarding nail holes in hardwood stairs Pat Fox Flooring 1 06-07-2010 09:41 AM
glue vs nail hardwood? BlueBSH Flooring 4 04-15-2010 12:48 PM
Would you staple, nail or screw? Speedball Flooring 7 11-28-2008 11:21 AM
