Old 03-02-2011, 04:10 PM   #1
Angry
Was my vinyl installed impropperly?
I had a small 4x10 sheet of vinyl installed a few days ago, but I think the installer laid it wrong. There are many bumps under the flooring, and my shoes leave tracks while walking on the new vinyl. He used a 1/4 notch trowel to lay the glue with, and used an entire quart for the area. Am I correct in assuming there is far too much glue below this vinyl, and this piece should be scraped and start over with new vinyl and new glue?
soldiermedic is offline   Reply With Quote
Old 03-02-2011, 04:18 PM   #2
you will need to know the manufacturer to determine what the glueing requirements are. Also on a floor of that size he should of been using a roller after placing vinyl down which would of squeezed out excess glue. Some vinyl floors are very cushy and will tend to feel spongy, but not to the extent they leave foot prints.
fixrite is offline   Reply With Quote
Old 03-02-2011, 05:51 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Sounds like too much adhesive. Most vinyls take 1/16x1/16x1/16 trowel. Some even 1/32x1/32x1/32. 1/4 inch trowel is for some ceramic, it will leave way too much adhesive for vinyl.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 03-02-2011, 09:13 PM   #4
Tileguy
JazMan's Avatar
1/4" trowel? Are you sure? Where did you find this person? A 1/4" trowel would likely use about a gallon, not just a qt. Please double check the facts.
However.......from what you say about the indentations.......someone owes you a new floor.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Tags
glue, vinyl
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 11:55 AM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
