My Flooring Project - Flooring - DIY Chatroom Home Improvement Forum
Old 03-08-2011, 05:44 PM   #1
My Flooring Project
Hi all,
I'm just beginning work on my home that I'm piecing back together. I'm starting in the bathroom, which is the only one of the house. I am debating whether I should let the bathroom share the same flooring as the rest of the home, or if I should use a different flooring scheme in it as to use it to "separate" the room from the rest of the home.
I'm leaning towards purgo clip-together laminate wood for the home, but am unsure if this would not be smart in a bathroom?
And on the other hand, I've been contemplating putting heated floors in the bathroom, but I'm not sure if it would support the type of floor I'm interested in. Ideas? Thoughts? Suggestions?
Thanks in advance.
Cm1384 is offline   Reply With Quote
Old 03-08-2011, 05:57 PM   #2
woodman58's Avatar
Most laminates do not do well in bathrooms. You should shop around to get one that is combatible with water areas. (wilsonart is one example). The best solution with heated floors would be ceramic.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Cm1384 (03-08-2011)
Old 03-08-2011, 06:00 PM   #3
Thanks!
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 12:01 PM
Another option for installing engineered wood flooring dutch Flooring 1 08-22-2010 02:28 AM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
Starting my flooring project... cbb7855 Flooring 4 01-13-2008 09:55 PM
