Is My Existing Underlayment OK For Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 12:10 PM   #1
Cool
Is my existing underlayment OK for tile?
Hi all,
I'm rennovating our house (a 1950 ranch) and am just about to do the kitchen. The existing floor over the joists consists of 3/4" wood strips covered by 5/8"plywood topped by what looks like 3/8" luan or plywood. I am going to put some type of tile (perhaps 12" or larger) and I know that ideally I should strip away everything down to the wood strips and then add new plywood and then cement/fiber board before tiling. The problem is that the plywood (which appears to be in good condition) is securely attached and I think will be difficult to remove. Also, the luan is really attached (glued?) to the plywood, so I can't easily remove it without doing a job on the plywood. So can I just clean up the surface of the luan somewhat (it has some black adhesive redidue) and the use a little self-levelling compound and then tile? I know tiling over wood is not ideal, but I did it in the bathroom using thinset specially designed for use over plywood and it came out great. Also, the floor is a little uneven, but solid and not at all bouncy. I might be able to put 1/4" cement board over the luan, but would like to avoid this due to height issues. Sorry for the long post, but thanks for any input!
Spudly is offline   Reply With Quote
Old 09-23-2012, 12:27 PM   #2
Rewards Points: 13,694
Tile should not be be laid over 1/4" , it needs to go.
Old 09-23-2012, 01:53 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
I concur with Joes post. The luon 3/8" or 1/4" needs to come up. Post a pic of what 3/4" ply you have and what the condition is that might need to come up as well. Joist specs are also is what needs to be considered as well for any tile.
JetSwet is offline   Reply With Quote
Old 09-23-2012, 02:31 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
And you must put thinset under the CBU.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 09-23-2012, 04:32 PM   #5
Hey all: thanks for the advice! I'm going to try to replace everything over the 3/4" wood planks. But as the original plywood is firmly attached, what might be the easiest way to get rid of it? I was thinking about using my circular saw to cut (down to the top of the wood planks) manageable squares in the plywood to pry up.
Old 09-23-2012, 05:08 PM   #6
Why not get rid of the old planks to? There not doing you any favors under tile.
And yes that the way to do it, just cut it in sections.
If any of it runs under a wall of under something like the cabinits you can use a Toe Kick Saw, it will cut right up againt the wall or toe kick with out damaging it.
I use one of these when demoing a floor.
http://www.thegutster.com/
Northern Tool is where I bought mine.
JetSwet (09-23-2012)
Old 09-23-2012, 08:06 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
The top layer of underlayment should be removed and hopefully was not glued, (should never be glued), anything is possible though. Can you cut into it and see. If stapled or nailed it'll come up fairly easily. Once gone, you can use the 5/8" ply as the base for your concrete backer or membrane, then the tiles. There is no reason to replace the 5/8" unless it's damaged.
Joe said;
Tile should be be laid over 1/4" anything, it needs to go.
He obviously meant to say, "Tile should not be be laid over 1/4" anything, it needs to go."
Jaz
JazMan is online now   Reply With Quote
Old 09-23-2012, 09:03 PM   #8
You are so right as always, I goofed big time on that one.
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 02:38 PM
Laminate Floor Underlayment Question hurt138 Flooring 4 11-08-2011 12:30 PM
Splitting an existing circuit run JoeyBradshaw Electrical 1 09-24-2010 08:02 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 02:00 AM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
