MVP4 Cure Time... - Flooring - DIY Chatroom Home Improvement Forum
Old 12-15-2007, 01:24 PM   #1
kemerick's Avatar
Rewards Points: 85
MVP4 cure time...
It has been 16 hours since laying down Bostiks MVP4 Moisture Barrier on my concrete clab and it is still tacky. My question is, does it cure hard or does it cure so it is a bit tacky? When stepping on it now after 16 hours, my boots stick a little and tracks are left. I have maintained the house at 70 degrees and 50% humidity.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 12-15-2007, 01:50 PM   #2
kemerick's Avatar
Rewards Points: 85
MVP4 cure time...
To answer my own question, I just got off the phone with Lumber Liquidators where I bought the stuff and they say it is normal for it to cure in this fashion. They say it is good to go as long as when I walk on it and it does not transfer to my shoes.
Help! A/C leaking big time IncHulk HVAC 5 03-29-2008 09:27 PM
When is it time to re-roof? oldkid6 Roofing/Siding 1 11-05-2007 08:58 PM
First time painting woes -- help! paintnewbie Painting 11 07-29-2007 01:42 AM
First time with old style fuses in fuse panel darsunt Electrical 3 06-20-2007 04:53 PM
Help! Water/Heating not heating at same time. flicksfan Plumbing 6 10-12-2006 04:55 AM
