Must I Remove Trim Before Installing Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 06:46 PM   #1
Must I remove trim before installing laminate?
I'm planning to install Pergo Laminate over an exisiting tile (vinyl) floor in our basement. As the room is already finished, the floor trim is already in place.
Is it essential to remove it in order to lay the floor correctly? I think I already know the answer; I just really don't want to remove the trim, since I recently painted it and don't relish the idea of doing touch ups on it or the wall or even possibly damaging something when removing the trim.
Any thoughts? Thanks!
Mary T is offline   Reply With Quote
Old 07-22-2011, 08:39 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
Yes, it needs to be removed.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Mary T (07-23-2011)
Old 07-22-2011, 08:41 PM   #3
you don't absolutely have to but then you would have to put shoe molding down to cover the gap. it looks more professional if you remove the trim. looks like a hack did it if you don't. If you go through any doorways you will need to trim the casing and door jambs for the laminate to go under them
The Following User Says Thank You to DannyT For This Useful Post:
Mary T (07-23-2011)
Old 07-23-2011, 12:12 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yup...you do.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Mary T (07-23-2011)
Old 07-23-2011, 05:51 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
That really depends on the type of trim you have. If it is shoe mold or quarter round then yes remove it. If it's baseboard, you could just add a piece of quarter round to cover the gap and leave the baseboard alone.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
Mary T (07-23-2011)
Old 07-23-2011, 09:55 AM   #6
Rewards Points: 146
I guess you are right, you don't have to remove the trim. That's the right way to do it, but many people who post on here don't want to do things the right way, only the easy way.
Mary T (07-23-2011)
Old 07-23-2011, 03:46 PM   #7
Doing it the right way.
Thanks, everyone for your responses. That's pretty much what I thought. I will remove the trim. Skip the extra cost of adding 1/4 round and just add some time to my project. It won't do much good if I hate the way it looks when I'm finished, even if I saved a little time.
Guess it's not a shortcut if I don't like where I end up.
Old 07-23-2011, 04:07 PM   #8
kwikfishron's Avatar
Rewards Points: 798
Iím glad to hear it. That ľ round has always looked like a mistake to me but people do it.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Mary T (07-23-2011)
Old 07-24-2011, 10:39 AM   #9
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I think it's really a matter of preference. Around here almost every house has quarter round on hard surface floors, regardless of the type. What I really hate is when you have painted baseboard and someone put quarter round that matches the wood floor down on it. That looks like a screw up to me.
Darkling Designs
Mary T (07-24-2011)
Old 07-24-2011, 11:00 AM   #10
I would agree on taking the baseboards off. It is tough to get them off depending on how long they have been on, the wood gets brittle over time, etc. Doing the quarter round method isn't terrible, but it just looks like a cover up. I've seen it on tile and laminate floors. The only way to leave the baseboards down and do tile is to undercut them. You might also want to take up the old floor, depending on how well it's stuck down. Then the new floor will only be as good as the old one is.
Like they say... You never have time to do it the right way, but you always have time to do it twice. (or something like that)
UCFWill2007 is offline   Reply With Quote
The Following User Says Thank You to UCFWill2007 For This Useful Post:
Mary T (07-24-2011)
Old 07-24-2011, 12:47 PM   #11
Rewards Points: 146
My house is 100 years old and has 1/4 round in every room. That is common in most old houses here. And we have the original oak floors.
Mary T (07-24-2011)
installing trim and moldings faintchimes Remodeling 5 04-08-2017 10:46 PM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 03:34 PM
Installing Laminate Flooring in Out-Of-Square House sweaty Flooring 1 05-25-2011 03:13 PM
Installing Base Trim - Transition from wood to carpet??? Quapaw Flooring 2 03-31-2011 06:56 PM
Installing laminate flooring ? ants1929 Flooring 10 02-24-2011 10:46 PM
