Motar - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 11:17 AM   #1
motar
can i use motar between laminate floors and tile floor?
rootbeer172002 is offline   Reply With Quote
Old 02-28-2011, 11:18 AM   #2
Rewards Points: 1,578
motar assumed to be mortar.
Which product is already installed on the floor? What kind of tile; vinyl or ceramic?
bob22 is offline   Reply With Quote
Old 02-28-2011, 11:43 AM   #3
Mortar Between tile and laminate
They are both already installed. There is about an 1/2 to an 1'' of space between the two.It is ceramic tile.
Old 02-28-2011, 12:11 PM   #4
So, any question or just an update on the project?
Old 02-28-2011, 12:23 PM   #5
Re:
Can I use the Mortar to connect the two together? The ceramic tile floor and the laminate flooring. They are both already installed. There is about an 1/2 to an 1'' of space between the two.It is ceramic tile.
Old 02-28-2011, 12:42 PM   #6
I think I get it now; these floors are side by side and you want to transition between them.
You need a transition strip of some sort; to get a good match you would best know the brand name and model/pattern of the laminate floor. That mfg will likely have a transition strip to go between the laminate floor and the tile floor.
See for examples, around page 26:
http://www.armstrong.com/content2/fl...iles/60076.pdf
The Following User Says Thank You to bob22 For This Useful Post:
rootbeer172002 (02-28-2011)
brick veneer IVANHO Building & Construction 4 01-26-2011 09:27 PM
Is a mud bed recommended for acrylic tub installation? jayp Plumbing 23 07-18-2009 01:02 AM
premixed motar? fabian Tiling, ceramics, marble 4 01-25-2009 09:36 PM
Motar for tile shower hayduke.klr07 Tiling, ceramics, marble 1 12-21-2008 01:50 PM
Can I dye existing brick mortar? Foo by Tore General DIY Discussions 2 10-30-2008 07:03 PM
