Most Effective Way To Remove Cut Back? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 08:10 PM   #1
The Big Builder
Most effective way to remove cut back?
Hello Everyone,
You may have read my other post that I am going to tile my concrete basement floor.
The previous owner had vinyl tiles and a black adhesive stuff I think people have called cut back.
The stuff looks like it is warn down pretty well but I am concerned about the new tiles sticking.
Is there a special adhesive I can use with the new ceramic tiles or do I need to use something to remove the cut back? Should I rent a concrete floor grinder and smooth it down that way?
What do you all recommend.
Thanks,
Stephen
bigbavarian is offline   Reply With Quote
Old 10-01-2009, 08:58 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
You can scrape the cutback, but I wouldn't grind it. It has asbestos in it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-01-2009, 10:55 PM   #3
DIY staff
Rewards Points: 7,174
Mepi and Latacrete make thinsets that will go over that nasty stuff..
Call a real tile store or check out JOHNBRIDGE tile forum.
Remove Pipe Vent from Asphalt Shingle Roof WaldenL Roofing/Siding 5 09-26-2009 02:46 PM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
back button not working joed Site Help and Suggestions 9 11-12-2008 01:08 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
