Mortor Mix Verses Thinset - Flooring - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 06:32 PM   #1
mortor mix verses thinset
I have 500 sq ft of mexican satillo tile i want to set on a concrete floor (covered patio). I would like to know if i can use a mortar mix rather than a thinset and if so do i add anything to the mortar. I have experimented and found that the tile absorbs the moisture so quickly you don't have time to set the correct spacing. I would appreciate any advice.
GMF
gmf123 is offline   Reply With Quote
Old 04-01-2009, 08:14 PM   #2
I gotta admit I'm not a saltillo expert, but my understanding is that when installing saltillo, one dips each tile in a bucket of water prior to setting it so it won't suck the water out of the mortar.
I don't know about the mortar mix... I think thinset and a trowel with fat notches, like 1/2 x 1/2 x 1/2 would be the way to go.
Maybe someone else here has more information.... Jazman? You out there?
Mudd is offline   Reply With Quote
Old 04-02-2009, 08:07 AM   #3
Thumbs up
mortar mix
Thank you i will try a couple of tiles and see if that works. I am still interested in any info on the mortar mix question. gmf123
Old 01-19-2012, 11:35 AM   #4
Question
gmf123
Did you ever try the mortar mix? Did the tile stick?
I'm going to try it in the bathroom with 4 tiles. I did some repairs and the floor not high enough. Going to level with mortar and place tile in mortar. Hope it sticks.
danfaub is offline   Reply With Quote
How big of a gap in hardie board can I fill with thinset? Constant Improvement Flooring 8 03-21-2011 06:43 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
Sand under thinset in Shower floor RodJ Building & Construction 5 03-27-2009 09:27 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
