Mortar Bed For Sloping Floor In Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 05:01 PM   #1
mortar bed for sloping floor in bathroom
My bathroom is 8' x 8'-6" with separate tub and neo-angle shower.
I'm on a raised foundation with a 3/4" ply sub floor; but sub floor is sloping quite a lot. 1" in 8 feet, so we decided to float the floor to level it out. Will be using 12x12 porcelain tiles.
Total float thickness on the high side of the room will be 1/2" (at the doorway) and on the low side will be 1 1/2" when floor is floated.
My question is: What is the appropriate fastener or fasteners to hold-down the metal lath (diamond mesh) ? If a staple, please specify which gauge and size.
Thanks for your suggestions.
Ken
ken24 is offline   Reply With Quote
Old 01-18-2012, 05:04 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 88
A "Jersey mud job" is not an accepted way to install tile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-18-2012, 05:24 PM   #3
DIY staff
Rewards Points: 7,174
Use a self leveling compound--mixed with pea gravel on the deep places---
I would think removing the subfloor and sistering in some new joists would be a better method--
What is causing the problem? If you will give us the size --spacing --and unsupported length
One of us will check the span chart and see if the floor is good for tile---
Old 01-18-2012, 07:39 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 346
Hi guys,
Rusty; what Ken described is not a Jersey mud job. He's planning a real mud job, although 1/2" is too thin. Make it 3/4" or so at the thinnest and all will be good ....... if everything else is done right.
Now that might be a very good way to go. Especially so if you're not all that comfy doing a mud-job. Let us know which way for more info.
Jaz
Old 01-18-2012, 07:46 PM   #5
thanks jazman,
Sounds good. How about the fastener for the metal lath going over 3/4 ply?
ken
Old 01-18-2012, 08:12 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 346
Staple length should be about 1/2".
Jaz
Old 01-18-2012, 08:18 PM   #7
Jaz man,
Can you specify what gauge of staple and crown width?
Are we talking about the kind of staples shot from a staple gun? or are we talking about arrow T-50 staples from a hand stapler?
Old 01-18-2012, 09:42 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 346
It's not that important. I have a few Arrow T-50 hand, another is electric type. Also Bostic hammer stapler. (best type, faster) I don't have the specs in from of me now. I think the crown is at least 1/2 wide, anything will work. In an emergency you can use nails, even finishing nails half driven then bent. I have used roofing nails a few times. Galvanized so they don't rust.
Jaz
Old 01-20-2012, 04:59 PM   #9
I practiced stapling some metal lath onto 3/4" ply using 1/2" long staples using the arrow T-50 hand stapler and noticed that the staples only go in about half-way; Then I used an arrow hammer stapler and that drove the staple down pretty well.
My only concern is the holding power of this these staples. I wonder if the mortar bed might dislodge from the sub floor with the up and down shaking of one of our earthquakes.
Old 01-20-2012, 05:13 PM   #10
Rewards Points: 774
Personally, I'd know the cause of the slope. We used self leveling in our living room and were able to carpet over it...., but tile could crack if the cause is not remedied.
cibula11 is offline   Reply With Quote
"Sandy" mortar on tuck-point repair drm31078 Concrete, Stone & Masonry 7 11-25-2012 08:18 PM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 07:44 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 11:13 AM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 04:53 PM
Removing mortar bed Cosmo Brown Flooring 2 04-04-2009 11:54 PM
