Old 08-26-2012, 03:44 PM   #1
Molded parquet black concrete underneath
I have to tear out molded parquet flooring in the morning. We are supposed to kill the mold on the concrete. The concrete underneath is solid black and doesn't scrape off. Is this cutback adhesive or would that be mold.. I heard that cutback had aspestous in it and that I shouldn't scape it. What should I do to treat it and install carpet back over it. Part of the floor will still have parquet flooring and part will be concrete. Should I install a piece if plywood over concrete after mild is gone then install carpet in top of that? Please help.
Christiev is offline   Reply With Quote
Old 08-26-2012, 03:57 PM   #2
This should been planed out before hand.
Why is there mold?
Going to need masks, Tyvec sutes, mildicide, http://www.baneclene.com/catalog/microban.html
Why does the flooring have to be removed?
Removing the flooring will open up a whole new can or worms.
Old 08-26-2012, 04:20 PM   #3
There was a ac leak in hallway. My job is to tear out and treat mold. I'm in an area that is out of my normal carpet cleaning experience. Haven't dealt with but 2 other parquet floors and it wasn't black like that underneath.
Old 08-26-2012, 05:21 PM   #4
It's called mastic or cut back. If it's old it can contain aspestos. (ya I know it's miss spelled)
Old 08-26-2012, 07:01 PM   #5
Thank you for your help.
Epoxy paint over black mastic over concrete in basement kidnitro6 Flooring 0 03-21-2012 03:50 PM
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 04:27 PM
Refinish/match old parquet or new hardwood? rational Flooring 1 04-29-2011 11:25 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
