Mold And Wet Plywood - Flooring - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 06:04 PM   #1
mold and wet plywood
we just found out that our washing machine drain hose has a hole in it. We pulled the machine out and found water behind the machine,so we started to pull up the vinyl tile and found mold and plywood to be very wet and swollen how can you tell how long it took to get swollen and start to mold?
PJS908 is offline   Reply With Quote
Old 11-22-2010, 06:15 PM   #2
ccarlisle's Avatar
Why is knowing that a concern? What difference does it make if someone says either three weeks or three days? If you have mould, then it probably took 48 hours, so at least two days ago...probably longer.
Now does knowing this change anything for you? does that change anything as far as the health issues are concerned?
Unless I misread the question, I suggest you just spend the time fixing it.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
