Old 08-27-2007, 01:31 AM   #1
Question mold under vinyl flooring
Hello everyone, I'm pretty new at home improvement projects so please be patient with me I've recently noticed a corner of vinyl peeling up where the bathtub meets the wall and underneath the vinyl there is some black mold..and there are also gray rings/spots on a ~12"x7" piece of the vinyl (I'm assuming its mold also).
Here is what I'm thinking of doing:
Cut the vinyl perpendicular to the tub, peel it back, kill the mold with bleach water, glue the vinyl back in place, then caulk where the tub meets the floor to ensure no water seeps underneath the vinyl again.
Or should I just find a new piece of vinyl the size of the area I want to replace and proceed as above starting with killing the mold?
sum07 is offline   Reply With Quote
More On This Topic
When you’re caulking around a tub or a sink, it’s important to dig out the old caulk first, especially if it’s grown some mold, because that will just go through the new caulk. So, it’s a little bit tedious, but it really is... Read More »
So we have completed our caulking. As you can see down here if you take a closer look, the corner that had a little bit of spacing, we just threw a little bit of caulking in there, cleaned it right up and anywhere where you have an extra crack, you can... Read More »
Cleaning the bathroom can take a lot of elbow grease and some household cleaners don't seem to work on everything you need it to. Still another use for WD-40. It's more economical than having a whole buffet of cleaners to choose from and it won't harm... Read More »
When you’re painting over mold or stains on your walls or ceilings, it’s important to kill the mold and to seal in the stain. So the first thing you want to do if it is mold is to kill it with a solution of bleach and some water. And it’... Read More »
Give a finished look to your new flooring by nailing a shoe, or quarter-round, to your base molding. By installing the shoe over the flooring, you will hide all uneven edges in the flooring at the perimeter of the room. Also, in older homes, you can... Read More »
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 07:20 AM
Mold on Vinyl siding jonesiera Building & Construction 1 09-08-2006 09:53 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 02:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 05:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
