Moisture Warped Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 12:12 AM   #1
Resi EC
Rewards Points: 252
moisture warped wood floor
This is an older home, sub-floor over crawl space.
The wood floor was installed without a vapor barrier so the wood warped.
If we sand the wood floor, and get it back to some what flat, install a vapor barrier under the sub-floor(in crawl space), will this keep it from warping again?
Thanks for any and all replies.
Gac66610 is offline   Reply With Quote
Old 10-09-2012, 12:57 AM   #2
Rewards Points: 13,270
Going to have to see some pictures to get a better idea how bad it is.
Warping is one thing, slight cupping is something else.
If this is soild hardwood I've never personaly seen one fix it's self just by drying out.
Old 10-09-2012, 07:26 AM   #3
Resi EC
Rewards Points: 252
Thanks Joe, I think cupping was the only term I could not think of.
Where the edges of the boards have turned up?
It is 1 x 6 pine flooring, it that matters.
I will see if I can get HO to send a picture or two,(it's about 2hrs away).
Its bad, she has thought about covering with carpet, but I think she will still feel the cupped wood.
She does not want to remove it, PITA, we removed the floor in kitchen. She was told it was a floating floor, she was misinformed. major PITA
Floor has settled, from kitchen to living room, about two inches in areas.
Old farm house (1928 I believe), that has been added onto numerous times.
Old 10-17-2012, 06:05 PM   #4
Moisture testing of the wood will reveal the moisture content of the wood typically should measure 6% to 9% regardless the subfloor cannot be more than 12% and the wood must be within 2%. Using an insulted pin moisture meter when the top and the board and the bottom are within 1% and your humidity less than 55% you can sand and finish and it should be ok. Most mfg's want humidity levels to not exceed 55% or go lower than 30% so you may need to get a humidifier or dehumidifier to control the inside environment.
IF the cupping is .01 to .015 that is considered normal and can be re-mediated.
Jim Decker is offline   Reply With Quote
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 04:23 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Wood floor sadness... DirtyTex Flooring 3 02-01-2011 06:20 PM
Best nail hole wood filler for hard wood floor Radjack Flooring 4 04-16-2009 09:17 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
