Old 05-23-2012, 08:31 PM   #1
moisture content of ceramic tile
I recenttly bought a 35-40 year old house-good structure. There were carpets over ceramic tile(original)
I was told the their was high moisture content and thats why I cannot have laminate floors installed.. There have never been any floods or leaks
sgulfman is offline   Reply With Quote
Old 05-23-2012, 08:34 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Who told you this?
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 05-23-2012, 08:41 PM   #3
I'm not even sure how one would be able to do a moisture test on ceramic tile. It's one of the hardest man made materials.
Sure it's not the subfloor under it that was tested?
Is there a slab, crawl space, or basement under the floor?
Carpet over a tile floor, hmm.
Old 05-23-2012, 10:24 PM   #4
Civil Engineer
There is essentially zero free moisture in ceramic tile. The actual percent moisture content is a function of the exact firing process, most porcelain tile is less than 3 percent water by weight, but that water is chemically bound up in the tile and would never impact floor above. Unless you do not have ceramic tile, moisture should be the least of your concerns.
Old 05-23-2012, 10:53 PM   #5
It was a dark and stormy
Yoyizit's Avatar
I thought the moisture was in your subfloor and it varied so a laminate floor on top would buckle??
ceramic tile over existing tile greg.digi Tiling, ceramics, marble 0 02-06-2012 10:44 PM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
