Moisture Coming Through Redwood Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2015, 11:22 AM   #1
Rewards Points: 2
Moisture coming through redwood subfloor
Hi,
I have a Victorian turn of the century home. I ripped out old carpet and refinished original plank redwood subfloor in my bedroom. Beautiful but huge mold problem in that room. Aside from larger fixes, what are folk's thoughts about putting rugs on top? I just pulled out large room sized rug for cleaning and its holding lots of moisture/smells moldy. Same question with heavy curtains. Are rugs and curtains trapping moisture and giving mold place to grow? Would I be better off letting it "breathe"? Temperature is not much of an issue, it rarely gets below 40 degrees here, especially this "winter."
Thanks!
noramounce is offline   Reply With Quote
Old 04-09-2015, 01:47 PM   #2
Rewards Points: 13,732
Need to figure out where the moisture's coming from.
Crawl space, basement under it?
If there's a crawl space is there a moisture barrier on the ground?
Moisture issues in the basement?
New subfloor over old subfloor GeneyLI Carpentry 8 04-06-2015 11:21 PM
Replace Rotted Subfloor Kory Beam Building & Construction 37 12-16-2014 05:17 PM
Tiling kitchen - Subfloor has a hump. Bigmo59 Flooring 10 09-10-2014 10:29 PM
replace a subfloor? french_guy Flooring 12 05-14-2013 03:12 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
