-   -   Moisture barrier for laminate wood flooring (http://www.diychatroom.com/f5/moisture-barrier-laminate-wood-flooring-78000/)
Blotz 08-05-2010 02:22 PM
I am installing Swiftlock laminate wood flooring by Armstrong. The flooring has attched foam base. Installation will be over concrete floor. Is an extra moisture barrier needed?
poppameth 08-05-2010 05:44 PM
Over concrete, I would recommend you put down a 6mm poly sheeting under it and tape the seams. It runs about $0.05/sf at Lowes. Are you sure you have Armstrong? Swiftlock use to be Armstrong but Lowes took Armstrong to court and won the trademark away from them. Now some Swiftlock is Armstrong, and a decent product, and some is Kronotex junk.
Oxymoron 08-05-2010 07:39 PM
I would suggest a dimpled moistur barrier such as Delta FL. I am using it in my install and it is real nice stuff....allows for air under floor. Google Delta FL
