Modified/unmodified Mortar - Flooring - DIY Chatroom Home Improvement Forum
Old 12-02-2007, 11:21 PM   #1
Rewards Points: 26
modified/unmodified mortar
What exactly is the difference and when should you use one over the other? Thanks for clearing this up.
ponch37300 is offline   Reply With Quote
Old 12-03-2007, 12:06 AM   #2
Oldguy
Rehabber's Avatar
Modified thinset has latex or other additives which allow a better/stronger bond. If you are putting down a backerboard for flooring, use an unmodified thinset between the backerboard and floor. You can use modified thinset everywhere else.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-03-2007, 06:23 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
From the TV show Holmes on Homes.
If your bonding:
porous surfaces, use modified
non-porous, use non-modifed
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-03-2007, 07:32 AM   #4
RippySkippy's Avatar
Originally Posted by Rehabber View Post
...If you are putting down a backerboard for flooring, use an unmodified thinset between the backerboard and floor. You can use modified thinset everywhere else.
With one exception...when installing tile on Kerdi...only use un-modified high-grade thinset.
RippySkippy is offline   Reply With Quote
Old 07-11-2009, 11:02 AM   #5
What about laying tile on a shower floor? Modified or unmodified?
RuthL is offline   Reply With Quote
Old 07-11-2009, 06:24 PM   #6
Rewards Points: 26
Ruth, you would probably be better off starting a new thread for your question. I've never done a shower floor but I know there is alot more to it than just modified or unmodified mortar. What kind of pre slope or pan do you have? Liner? Drain? Lots of things that you need to share to get an answer
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Backerboard not in mortar -- How bad is that? House_Amuck Flooring 28 09-27-2010 10:33 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 08:38 AM
Is Structalite up for Tub-setting (instead of mortar?) House_Amuck Plumbing 2 03-20-2007 06:09 PM
can I reuse mortar bed ? mf915 Flooring 1 07-04-2006 07:14 PM
