Old 11-24-2006, 01:13 PM   #1
Default Mixing Hardwood, Carpet, and Laminate!
Hi,
We live in a 1100 square foot duplex with 3 dogs and 3 cats! We have having some problems with our flooring! When we moved in there was already oak hardwood on the 1st floor, and carpet everywhere else. Since we have installed laminate, but not hardwood before, we decided to use a laminate in the master bedroom. We have carpet in the loft, the guest bedroom, the hallway, and the stairs. I have heard that laminate and hardwood are both difficult and noisy as far as the stairs go, but I don't want to deal with carpet in the loft with the animals. We were thinking of using laminate in the loft, but leaving the carpet on the stairs the hallway, and the guest bedroom....would this look "off". Here are pics of the layout:
We plan on using the same laminate as the bedroom. This would be the cutoff point:
Thanks,
Amy
reptilicus81 is offline   Reply With Quote
Old 11-25-2006, 11:28 AM   #2
i think it would look ok as long as you put a laminate to carpet strip
gedereco is offline   Reply With Quote
Old 11-25-2006, 12:16 PM   #3
Darylh's Avatar
If the corner of the wall is not the same distance as the board at the bottom of the railing then it might look a little funny being offset so I would either go with my pic but you could also cut the carpet off at the top of the riser and put a transition piece here that overlaps the carpet( second pic).
mixing-hardwood-carpet-laminate-carlaminate.jpg   mixing-hardwood-carpet-laminate-carpettolam.jpg
www.geocities.com/edimprovement
Darylh is offline   Reply With Quote
Old 11-25-2006, 10:43 PM   #4
Super Moderator
Floorwizard's Avatar
also keep in mind that you are keeping carpet in the highest use points in the home. the hall and stairs.
you will be replacing more often.
but the layout seems fine.
Time to ride again!
Floorwizard is offline   Reply With Quote
More On This Topic
How to Decorate a Hallway
How to Decorate a Hallway by Expert Village
Hi my name is Frank Clarke with Oliver and Associates Realty in London Ontario on behalf of expertvillage.com. I would like to speak with you briefly about hallways, entrances, staircases, etc. for the purposes of selling your home. Please be sure the... Read More »
Creating a cozy bedroom starts with decluttering the room. Cluttered rooms don't feel cozy or inviting. It's easier to create a cozy bedroom by focusing on it as a place to rest, steering clear of squeezing in room for sorting out household or work... Read More »
We spend more time in the bedroom than most other rooms in the house on a daily basis. Keeping the bedroom as dust free as the rest of the house should be a high priority. Spending time each day or once a week cleaning the bedroom can make a big... Read More »
This Greek Revival residence has been called home by people as diverse as Sam Houston, Ma Ferguson, John Connally, Ann Richards and George W. Bush. It is one of the oldest governor's mansions in the United States and oddly, one of the smallest. Read More »
Hello my name is Denise Robinson on behalf of Expert Village I'm here to talk about the loft. How to take a space a large space and divide it up into small living quarters. Now I'm going to add the futons to make up our bed in our bedroom. Like I said... Read More »
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 9 12-22-2008 11:53 AM
carpet vs. laminate?????? oblesq Flooring 15 07-31-2007 01:32 AM
Carpet vs Laminate and Vinyl vs Ceramic Kaminberry Flooring 5 02-26-2007 09:03 PM
laminate better then hardwood? Jack Hass Flooring 6 12-19-2006 08:12 AM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 11:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
