The installer said it was very sandy and kept leaving a haze behind. He told us that he had to rinse the grout 5 times.
That right there is likely the cause of the grout color variances.
The problem is that the surface is dull in places and scratched where he floated the grout.
Can't likely happen.
It is almost as if he wore the finish off the tile.
Can't happen, that's just plain digging up issues to fault someone for. Not scientifically possible at this stage of the process.
...the surface was acid (?)washed away.
OH NONSENSE!!! Not with vinegar it wasn't.
Go get YOURSELF some Murphy's Oil Soap and a white 3M scrubby (I doubt that either is necessary) and scrub that floor then rinse it a few times with clean water. New water each time you rinse. You'll be fine.
There is no way what you have described could happen to that tile floor.
