Mirage Floating Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 05:12 PM   #1
Has anyone installed Mirage's new "Lock" floor?
Does the underfloor need to be perfectly level?
Does the lock hold even with heavy file cabinets?
Geri is offline   Reply With Quote
Old 02-20-2009, 03:05 AM   #2
I haven't installed it, but I can offer two bits of advice.
In general, with any type of flooring, the subfloor should be clean, dry, flat, and sound.
Floors expand and contract with changes in temperature and humidity; that's why they need an expansion gap.
If you take a floating floor and put some screws into it, fixing some planks in one spot, when the floor needs to expand or contract, it can only do so up to the planks that can't move.
Putting heavy furniture on a floating floor is the same as screwing down the floor where the item sits.
Sometimes a gap between planks will appear in floors in front of heavy pieces of furniture that pin parts of the floor down.
Mudd is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 07:23 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
