Mirage Engineered Wood- Acclimate Or Not ? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-19-2014, 11:24 AM   #1
Mirage Engineered Wood- Acclimate or not ?
Mirage claims you don't have to acclimate their engineered wood floors even in Florida. The company doing the install is insisting & says it can't hurt anything. He said keep the temperature around 75 and humidity at or under 50% & we'll have no issues. Some times keeping the humidity at or under 50% means we have to drop the AC to 72 or 73 which is cold.
Can anyone with experience tell me what their thoughts are on this?
Thanks Anne
annestrauss is offline   Reply With Quote
Old 04-19-2014, 12:34 PM   #2
Rewards Points: 144
Like they said.It sure can't hurt anything.I have never seen any kind of flooring that it was not a good idea to acclimate.It is a fact of nature that wood moves.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
joecaption (04-19-2014)
Old 04-19-2014, 12:36 PM   #3
Rewards Points: 144
Another quick point.If I was installing you're floor and wanted to let it acclimate and you insisted on putting it in now.Any problems down the road are on you.I'm no longer responsible.
Old 04-20-2014, 09:13 PM   #4
Rewards Points: 150
Why not let it sit for a week?
joemontana16 is offline   Reply With Quote
Old 04-22-2014, 01:41 AM   #5
Rewards Points: 744
Follow the manufacturer's instructions and you shall be fine. Engineered is more stable than solid.
Seattle2k is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Laminate vs Hard wood vs Engineered?? Gecko Flooring 1 02-22-2012 06:35 AM
Suggestions for engineered wood over OVRX insulated subfloor in basement? MasonS Flooring 2 12-14-2011 08:59 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
engineered wood floor lost Flooring 13 10-11-2007 10:49 PM
