Minwax Fast-drying Polyurethane On Table Top(too Thick) - Flooring - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 11:42 AM   #1
minwax fast-drying polyurethane on table top(too thick)
product applied too thick ? will it eventually dry? using for work bench. first coat went on well(over masonite) but second coat was applied thicker to help level area out,its been 48 hours and you can push material with hand and leave wrinkles but they eventually settle out.table is outside under the sun,will it eventually dry or do i need to do something else. want to add more coats after it dries.
richard d is offline   Reply With Quote
Old 09-14-2010, 07:28 PM   #2
Handy Vinny's Avatar
Rewards Points: 150
I am not sure I understand this.
You are saying that in its last application, the end result was too thick, but you plan additional coats, correct? You are also wondering if this will eventually dry?
Have you ever worked with this material before?
I have never had this problem with any Minwax product.
Handy Vinny is offline   Reply With Quote
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 10:50 AM
Minwax Floor Polyurethane JulieO2428 Flooring 2 09-21-2010 03:04 PM
Minwax Polyurethane for Floors ggcanner Flooring 2 11-18-2009 06:36 AM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 08:48 AM
primer drying too fast farrington135 Painting 3 07-18-2006 05:16 PM
