Minimum Row Length For Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 01:47 PM   #1
Minimum row length for laminate flooring
I'm reading the instructions for my st. james collection laminate floors and it says "the planks at the end of each row must not be shorter than 12" to insure stability, if your last plank is shorter than 12", it is advised to re-cut the first plank in the row." Now in the room i'm doing the flooring there's a little 'hallway' that is 33" wide, how do i have enough variation in the plank pattern but still have atleast 12" in each of the planks i put down? there's going to be 5 rows in this little 'hallway'
Hyperian is offline   Reply With Quote
Old 07-14-2008, 02:16 PM   #2
Can't you span the entire width with a plank?
perpetual98 is offline   Reply With Quote
Old 07-14-2008, 03:02 PM   #3
Yes, there's a plank that's wide enough to do that, but i am not sure if i want to do that 5 times in a row?
Old 07-14-2008, 03:12 PM   #4
Why wouldn't you? I've never heard of it being a BAD thing, but who knows, maybe it is?
Old 07-15-2008, 01:36 AM   #5
well i guess there's nothing technically wrong with it, it's just that it might look weird or ugly, maybe a split in the middle every other row would be nicer?
Old 07-15-2008, 07:38 AM   #6
Get out of the box!
Rewards Points: 260
I would sugest every fourth plank be full and that will help you keep your stagger as random as possible.
You must have a stagger to keep a consistant look.
If you get a repeat in your stagger within 6 planks it will not be that uncommon nor noticable.
26yrsinflooring is offline   Reply With Quote
Old 07-15-2008, 09:45 AM   #7
Are we talking the fake wood laminate? I guess it would depend on the style. The stuff I'm familiar with is about 48" long, and 6" wide and is composed of a print of a bunch of boards together all staggered. If the laminate you're putting down has the appearance of 1 board, then yeah, I would probably stagger too.
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 02:47 PM
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 12:01 PM
Hallway Flooring jay1000 Flooring 3 05-30-2006 07:04 PM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 09:53 PM
