Old 02-26-2008, 07:18 PM   #1
Mildew underneath tile
I had mildew in my tile caulking and cleaned it. I noted the tiles were loose and popped one off. Underneath the tile, I fold mold/mildew. I have sprayed it with 50/50 bleach and water. Can I lay the tile back on the wood surface ? Any suggestions re sealing the wood and then retiling ? Should I use a thinset ?
Thanks.
budfava is offline   Reply With Quote
Old 02-26-2008, 07:58 PM   #2
Tileguy
JazMan's Avatar
A total rip out is in your future. Anything you try now is temporary.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 02-26-2008, 08:57 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Gut it out. Remove any damaged wood materials and replace. Undamaged wood = Spray with a Fungicide. Bleach will not kill mold spores on porous surfaces (like wood).
- Build Well -
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
