Micore Board On Concrete Slab Floor Before Granite Hearth? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-19-2013, 11:52 AM   #1
Rewards Points: 640
Micore board on concrete slab floor before granite hearth?
I am putting in a built in electic fireplace (39" wide one) and we are going to do a granite facing, with that comes a 1ft wide by 66" long granite hearth...
The floor is a granite slab, do you still need to put a micore board under this, or can granite be placed right onto concrete with no problems?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 01-19-2013, 12:19 PM   #2
Rewards Points: 13,270
Right on the concrete is the way to go.
Old 01-19-2013, 12:33 PM   #3
Rewards Points: 640
that's what my original plan was until I got the instructions with the granite facing kit and it says "use micore board on concrete slab to stabalize granite hearth" how much more stable then concrete can you get? I was thinking this is a misprint and that should of been for a wood subfloor?
Old 01-19-2013, 01:32 PM   #4
i would follow the manufacturers installation instructions or your warranty will be null and void.
Concrete over brick over post tension slab M3 Pete Concrete, Stone & Masonry 6 01-21-2013 06:37 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 12:49 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 05:11 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
