Method For Installing 3/8" Engineered Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 12:48 PM   #1
Rewards Points: 129
Method for installing 3/8" engineered hardwood
I'll be installing about 1000Sqft of Shaw Epic hardwood in my new home. I"ll be installing it on top of 3/4" Advantech T&G subfooring (over a crawspace in North GA).
I can either nail/staple it down or float it. What are the pro's and con's of each of these methods?
poolecw is offline   Reply With Quote
Old 10-23-2008, 05:34 PM   #2
Get out of the box!
Rewards Points: 260
What is your board width ?
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 10-24-2008, 06:16 AM   #3
Rewards Points: 264
I have been getting ready to put in new floors and will float mine. One advantage is that the floating can be easier to repair.
I am interested to see what the pro guys and others say about this topic!
7echo is offline   Reply With Quote
Old 10-27-2008, 08:05 AM   #4
Rewards Points: 129
The boards are 5" wide....
Old 10-27-2008, 09:35 AM   #5
Nailerman
Staples are the best way to go. They offer a tighter more solid feeling floor. The floating floors have a tendency to make you feel like your floating.
nailerman is offline   Reply With Quote
Old 10-27-2008, 10:57 AM   #6
Get out of the box!
Rewards Points: 260
Float it!
No problem at all to float them. It is much less work and much less floor prep.
You will also have the option of an underlayment that will keep the wood warmer, winter is here!
This underlayment will also keep the floor cooler come summer.
You will a slight echo effect but many times you get a an echo if installing any way do to slight voids in the floor.
Since you have thc choice I say. Float it!
Old 10-28-2008, 11:49 AM   #7
floor tip
One thing to remember when installing wood is to leave a little room for it to breathe. Our contractor allows a little gap around the perimeter of the room and then the baseboards covers it. One home owner did his own and didn't do that and some boards started buckling with the temperature changes.
Allison1888 is offline   Reply With Quote
Old 10-28-2008, 01:41 PM   #8
Get out of the box!
Rewards Points: 260
You are correct
Leave at least 1/4 expansion along all your walls.
Old 10-30-2008, 08:26 PM   #9
Floater
Lay down a Floormuffler underlayment......absorbs the hollow sound you get from most floating floors.... also acts as a moisture barrier.
Gevans17 is offline   Reply With Quote
Old 10-30-2008, 09:38 PM   #10
Get out of the box!
Rewards Points: 260
I prefer Quiet Walk by MPGlobal it is all I use.
Old 10-31-2008, 03:10 PM   #11
I just read the installation procedure for a product by that name. From what I read I would staple it. I personally don't like the thought of glueing joints and wiping of the residual glue I always get on the surface . It will be firm as nailerman already stated. Hope this helps.
monarksky is offline   Reply With Quote
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
Hardwood - engineered vs solid? cbeingessner Flooring 12 05-19-2008 10:37 AM
Quality of Pergo engineered HARDWOOD? Jeff12 Flooring 2 01-13-2008 09:17 PM
engineered hardwood installation; Floating or Glue? El Buey Flooring 4 08-17-2007 02:53 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 09:03 AM
