Metal Trim For Vinyl Flooring Against Bathtub - Flooring - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 06:03 PM   #1
My house is approximately 35 years old. It has sheet vinyl flooring in both bathrooms, with a thin metal molding along the bathtub to hold down the sheet vinyl. The part of the molding that shows is a 1/4"x 1/4" quarter round. A nailing flange is attached to the molding and the sheet vinyl goes over the flange and under the molding. The molding looks good and has held up very well over the years.
I am in the process of remodeling my mother's two bathrooms, including installing new sheet vinyl flooring. Most of what I read indicates the sheet vinyl should just be glued down and caulked at the bathtub, but I would prefer the thin metal molding for both appearance and to keep the sheet vinyl from curling up. Does anybody know exactly what this molding is called and where I can find it? I've checked on-line and at all the local flooring stores.
Lynden is offline   Reply With Quote
Old 09-12-2012, 08:05 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Haven't seen any of that for years. There is a clear vinyl piece that is L-shaped that you can stick on the edge of the tub to cover it. It is peel and stick.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-12-2012, 08:32 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
Linden,
There is nothing made specifically for that purpose, you are supposed to cut to fit and caulk as you said. But, they probably used a cove metal, it's usually used on stair tread/risers inside corner. Looks like this; http://www.google.com/imgres?q=alumi...9,r:3,s:0,i:84
It will work if the tub is straight, which most are.
Jaz
Old 09-12-2012, 09:54 PM   #4
Rewards Points: 14
That would probably work Jaz, there was a metal used for vinyl edges many years ago, but I haven't seen it for a long time.
Old 09-12-2012, 10:40 PM   #5
Rewards Points: 12,852
If I get stuck doing one I've been using vinyl cove moulding set in a bed of silicone.
Old 09-13-2012, 11:00 PM   #6
Originally Posted by JazMan View Post
Linden,
Jaz
Thanks everyone for your replies.
JazMan: If I can't find the molding I'm looking for, the one you linked looks like it will work and I'll give it a try.
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 07:37 AM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Paint a metal bathtub?? Please help! Sarah24 Painting 1 03-16-2008 08:21 AM
