Metal Strip Between Carpet And Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 05:05 PM   #1
Metal strip between carpet and tile
There is a piece of metal (aluminum?) covering "border" between the carpet in my master bedroom and the tile in the bathroom. It was held down using 4 nails but recently it seems to be coming off. 2 of the nails popped out when the vacuum cleaner hit it as I was cleaning the bedroom.
These nails have a history of popping up and previously I've just hammered them down again. I want to check here and see if there's a better way to ensure that they stay down this time?
Perhaps use long screws instead? Thanks.
bigbearbear is offline   Reply With Quote
Old 09-13-2012, 07:28 PM   #2
Rewards Points: 13,270
Without a pictue not sure how anyone would know which one you have.
Old 09-14-2012, 05:18 PM   #3
Rewards Points: 3,414
Sure just use brass screws,and that should solve your problem.
Canarywood1 is offline   Reply With Quote
tile to carpet transition jburchill Flooring 3 07-12-2012 09:38 AM
Schluter strip between tile and carpet kidsncats Flooring 3 05-02-2012 12:11 PM
Where tile meets carpet FirstAndTen Flooring 2 02-17-2011 07:20 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
