Metal Stair Nosing Over Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 11:22 AM   #1
Hi all,
I have just installed TrafficMaster Laminate flooring in my kitchen. Now I have to finish the stair nosing.
Home Depot said they do not carry the laminate stair nosing, and that they have to special order it-seems weird, but that's what they said, and I couldn't find it anywhere in the store. It seems like all the laminate-specific trim is fairly expensive, and so I was wondering if it is ok to finish the top stair nose with the cheap metal kind that you can get for like 6 bucks. The kind that just looks like an "L" that you nail down.
I don't care about the look, it will be hidden under the door to the basement anyway.
I was just thinking it might be bad to 1) nail into it, since it is a floating floor and 2) the metal might scratch the floor. To avoid nailing directly into the laminate, I was thinking of placing a piece of plywood under the nosing to support it, and just have the lip of the nosing overlap the laminate.
Any thoughts?
Thanks,
Meghan
mrlang02 is offline   Reply With Quote
Old 05-09-2012, 07:03 PM   #2
Thadius856's Avatar
Rewards Points: 504
I'd just special order the stuff. Usually if you're patient enough to wait for it to come in, they don't charge the shipping to the store. Seems silly to me to spend the time and money on the laminate to cut a few bucks off on the moulding.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 05-09-2012, 07:29 PM   #3
Rewards Points: 14,312
And what your going to get is a L shaped piece of what looks like ground up cardboard with peel and stick shelving paper over it that's going to be a trip hazzard.
JetSwet (05-09-2012)
Old 05-09-2012, 07:47 PM   #4
Nailing a floating floor, or attaching a tight fitting strip to it will cause the pieces to pull apart.
Old 05-09-2012, 07:48 PM   #5
Thadius856's Avatar
Rewards Points: 504
She said the door goes to the basement. This is most likely on the first floor. She did not indicate that the stairs were done with this laminate, either.
Old 05-10-2012, 04:24 PM   #6
I agree. i would get an actual stair nosing. You will be glad you did and the cost is relatively cheap. You can likely find them online.
RhodesHardwood is offline   Reply With Quote
Old 05-21-2012, 05:02 PM   #7
ok thanks for the advice guys!
Tags
laminate flooring , stair nosing
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
refinishing metal indoor stair railings nastyes Building & Construction 1 08-08-2010 12:51 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Painting Metal Stair Railings DanielleEglsNst Painting 8 10-08-2008 03:08 PM
