Old 06-28-2012, 09:44 PM   #1
Mesh showing through glass tile
I'm installing 1x2 clear non colored glass mosaic 12x12 tile. I did a very smooth float on the mortar, pressed it in good, and slid it around a bit, then grouted. Used white premixed high quality mortar and white grout. The tile is 1/4" thick with white paper backing. The problem is on the bottom of the tiles, where you can see through the 1/4" clear part, you can see a very thin line of the mesh. Can anyone tell me if this is preventable, and how? Also, I pressed the grout in pretty hard, so I don't think that's the issue. Thx
Stanchek is offline   Reply With Quote
Old 06-28-2012, 10:35 PM   #2
Your using clear glass tiles, and you can see through them, hmm.
Old 06-28-2012, 10:38 PM   #3
Haha, really, that's the best you got? Do you think I did everything properly, but the the tile being clear is always going to show a bit?
Old 06-28-2012, 10:46 PM   #4
Super Moderator
A little backing showing on a clear glass tile is to be expected--
I am concerned about your choice of premixed adhesive instead of thin set---
That is not in a wet area like a tub or shower,I hope.
Old 06-28-2012, 10:48 PM   #5
Looks good to me. There should be a surcharge for that.
cleveman is offline   Reply With Quote
Old 06-28-2012, 10:51 PM   #6
Not a wet area.
The Following User Says Thank You to Stanchek For This Useful Post:
oh'mike (06-28-2012)
Old 06-28-2012, 10:52 PM   #7
I have had the same thing happen to me also having using the same color mortar. You are probably the only one who will notice it. Your tiles look especially clear, so I don't think it really can be prevented on these.
RhodesHardwood is offline   Reply With Quote
Old 06-29-2012, 09:11 AM   #8
Looks good/normal to me. The small glass tiles in my backsplash look the same if you look close enough. Nothing you can do about it, but you only notice it if you look at it very closely. Nice work.
NewHomeDIYGuy is offline   Reply With Quote
Old 07-02-2012, 01:07 PM   #9
So here's the deal. the designer had me tear out the tile that I posted in the picture. I had my granite guy install this backsplash, and after telling the homeowner what all you guys said here, I asked her if she wanted to install the same tile and live with the mesh showing or go with a different tile. She said they could live with it, and to install it again. At this point I'm out $300 for the tile. So my granite guy comes and installs it again, and it looks the same as it did. Well I get a call today that she was watching all sorts of online videos, and that it CAN be installed without the mesh showing. So she wants it torn out AGAIN. I called in my regular tile installer who always does a pretty good job for me, and he says it would look exactly the same if he did it. So my question is, are these guys just not that knowledgable on glass tile install? I'm losing my mind on this one. Does anyone have any advise? Plz help.
Old 07-02-2012, 01:30 PM   #10
Renovations contractor
Bonzai's Avatar
First off this is a DIY forum ... perhaps you want the 'Contractor Talk' forum.
Second, it's transparent glass tile you are installing ... of course you can see through it, just like any clear window. Tell the designer to spec a non-transparent tile if they & the home owner have an issue with seeing through it.
FYI: I feel for you as I get my share of clients who don't understand the nature of the product they selected ... usually with slate when they don't understand that every piece is different despite telling them.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-02-2012, 01:31 PM   #11
Wow, sounds like you have a very difficult/pita designer/customer. I'm no GC but here are my 2 cents. The "problem" with glass tiles is that they only have a paper backing on the back (which is colored so the the glass tile then has a color (gray in this instance)). With a mesh backed mosaic sheet, when you press the sheet into the thinset, it's going to INEVITABLY have a little press through the ridges, which creates the little "bump" looking parts around the tile. Since the thinset oozes around the side past the side of the tile and the paper isn't covering this area, it will be visible through the tile. That seems completely unavoidable to me, and really is barely noticeable.
The only other option would be to choose a mosaic sheet that doesn't have a mesh backing. I thought I remember seeing these at the local tile store. Basically they just have a paper facing on the front side, which you remove after the sheet is semi-dry in the thinset. This should result in no "bumps," but there is always going to be SOME thinset that will be visible, just like the mesh backing, although it shouldn't look like small bumps.
Good luck. Sounds like the designer doesn't know what they're doing.
Old 08-24-2012, 12:23 AM   #12
Mesh showing through glass tile-image-1682870505.jpg   Mesh showing through glass tile-image-3871091639.jpg   Mesh showing through glass tile-image-2939969122.jpg   Mesh showing through glass tile-image-2101944613.jpg   Mesh showing through glass tile-image-4232229011.jpg
Old 08-24-2012, 12:24 AM   #13
Thought I would post some pics of the finished product. Pics aren't that great, but the job DID turn out great.
Old 08-24-2012, 05:18 AM   #14
Super Moderator
Did the customer pay in full?
Looks fine,by the way.
Old 08-24-2012, 09:28 AM   #15
They did. They were very happy in the end.
oh'mike (08-24-2012)
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 48 05-14-2013 10:43 PM
What Size Trowel for This Glass Tile? Renovatings Tiling, ceramics, marble 26 10-29-2012 09:24 AM
Sealing grout on a glass tile mosaic backsplash? smithers76 Tiling, ceramics, marble 1 05-08-2011 07:44 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
removing glass 4x4 tile tilewoes Building & Construction 1 06-10-2008 10:54 PM
